Crawford V5 plenum install problem.
Old May 8, 2006 | 05:06 PM
Jeff92se's Avatar
Red Card Crew
I checked Crawfordz's site but didn't see it in the Q & A. Unless it's part of their video. But I do understand what to look for and I do have an air powered grinder handy. And a Dremel.
Man that squeal was so loud, I thought it was going to wake up the neighbors next door. I had the garage door open at 1:30 am. haha
Old May 9, 2006 | 11:38 AM
Jeff92se's Avatar
Red Card Crew
I checked it closely again. You were right. The two mounting bores are higher. But I can tell it's because they were torqued down too much and caused the top of the plenum to become concave. I wonder if I can gently bend it out to make the top flat or even slightly convex?
Also the flange face in the front of the plenum actually bows up a bit. I talked to buddy that has the same one. They ended having to use two gaskets. I also note that there was some gasket sealer on the flange of this one.
Old May 9, 2006 | 04:31 PM
Jeff92se's Avatar
Red Card Crew
I also found a thread describing the same problem. Seems a double gasket might be the solution. If I install the outer bolts first, it might solve the concave problem of having the two mounting bores being too long.
http://www.my350z.com/forum/showthre...awford+problem
Old Jun 29, 2006 | 04:10 AM
richie's Avatar
Jeff, did you ever fix this?
Old Jun 29, 2006 | 11:31 AM
Jeff92se's Avatar
Red Card Crew
ha Richie. No. I haven't had the time to try. I plan on doing the install this weekend (again!). I'll post and report.
G35Gnome
30
Apr 29, 2005 08:20 AM
Msedanman
Apr 23, 2004 03:02 PM
g35gandu
Intake & Exhaust
32
Jan 23, 2004 05:37 PM
ChrisG35C
Nov 28, 2003 03:32 PM
ericinmia
Intake & Exhaust
Aug 10, 2003 03:14 PM
