Greddy Side Skirts Question?
Old 10-28-2006 | 09:17 AM
G35SHAWN's Avatar
Sometimes next week, i am dropping my car off to the bodyshop in the morning to get my greddy side skirt installed. However until last night just had me thinking, with my "350z" tein S-tech, how bad will i scrape once i get that side skirts installed?.
I also hope that i wouldn't have to go through any problems putting the car on the lift. Anyways those with greddy side skirts please chime inn.....
Old 10-28-2006 | 01:58 PM
G35SHAWN's Avatar
Originally Posted by HomieG35
Hey Shawn! Hows everything going? Still loving those Test Pipes [so does the EPA!]. I have the GReddy fron and sides on my car with 19'' rims and stock suspension. I have the same exact springs [came off a 350Z] and the reason I haven't put them on yet is because I was going to do it at the dealer but when they go to lower the car off the lift... it will hit. As it is we have to lift up on the car to get the lifts under the side skirts. They say the springs will lower the 350Z .5 and .7'' and it will lower the G about 1.0'' all the way around... Good luck and post pics!
What's going on bro, how is it going. Very happy to hear those test pipes are working good for you. Once i put em on will definetly post pics..Thanks again.
Old 10-28-2006 | 02:32 PM
GReddySetGO's Avatar
How low are your 350Z S. Techs in comparison to the G35 model? I have G35 S. Techs and it sits pretty low. I have to drive on 2 pieces of wood, 1 at a time to get onto the lift. Other than that, if you know how to drive a lowered car, you'll be fine. I have about 4" of clearance for mine, just ANGLE!!
Old 10-29-2006 | 01:23 PM
FastDontLie's Avatar
...we dont need roads...
Getting & installing my greddy front and sides this week, Sitting on tein 350z h techs & 18's. Cant wait to see what its going to look like, good luck with your install.
Old 10-31-2006 | 07:06 PM
Rphillips6487's Avatar
greddy front and sides.. no rear?
Old 10-31-2006 | 11:17 PM
BLacK_G35_CouPe's Avatar
juss to add to his question...im on 19s stock suspension...i have AIT side skirts and have to take them off everytime to get it lifted because it will be crushed if i didnt...so my question is if i had the greddy sides with stock hieght, i know gettin onto the actual lift will be fine, but will i need to take them off to actually lift?
^ yea worded funny...but please help...thanks
Old 11-01-2006 | 01:49 PM
If I can raise my car w/ GReddy sides on, dropped. You should be fine on stock suspension.
Got pics of your AIT sides? Why do you have to take them off to get on the lift? I just drive on top of wood first...
Old 11-01-2006 | 08:55 PM
here some pics...everywhere i go they will not lift the car because they say they will break (because i guess there is too much space between the skirts and the actual frame of the car), so i have to take them off in order for them to LIFT it...gettin over/onto the lfit is no problem...LIFTING it is the issue...but Greddysetgo, you can take your car to the dealer and they lift your car no prob with the sideskirts still on? nice ride btw
Attached Thumbnails Greddy Side Skirts Question?-cimg1698.jpg   Greddy Side Skirts Question?-cimg1694.jpg
Old 11-01-2006 | 09:27 PM
GreenGoblin's Avatar
The goblin resurrection
^ nice whip looks killer
Old 11-02-2006 | 10:40 AM
Otacon132's Avatar
im on stock height and i scrape everywhere in miami if i am not carefull, my front bumper more than anyhting - side skirts give me a problem only when i putbthe car on a lift.
Old 11-02-2006 | 12:11 PM
Those sides look to be about similar size as GReddy. Its true, there is too much gap between the bottom of the skirt and the lift points, but most lifts have an arm you can flap up, or twist up to make it higher.
I have my own shop and my own lift, so I put it on myself, and its fine. But yes, the dealer has done it too w/o any problems.
Old 11-02-2006 | 12:12 PM
I'll take some pics of the little flaps on the arms that I'm talking about when I go to work later.
Pretty much all lifts has some type of adjustment point on the arms, they are mostly used for trucks and things like that when they are really high off the ground. But work great in this case also.
Old 11-03-2006 | 12:30 AM
its such a pain in the *** to take them off...plus the 20 mile drive to Jax without side skirts...people laguh at me ... haha jk but car looks real funny without it...im most likely gettin the greddy sides within the next few month...as you can tell i need to respray my front bumper...but yea appreciate all your info greddysetgo...and ill be checkin on this thread to see exactly what you mean...thnx
Quick Reply: Greddy Side Skirts Question?
