Window cracking noise.
Old Jun 2, 2007 | 09:08 AM
hfgreg's Avatar
After a search of the forums I could find nothing on this. Recently I started to notice that after I closed my door, the window would slide up and seal, but after it was up its trying to push further up creating a cracking like noise. Anyone have any idea whats doing this? Is the motor going out?
Old Jan 17, 2008 | 05:36 PM
vasqo's Avatar
have the same issue... have no idea what it is...
Old Jan 17, 2008 | 06:20 PM
Bigd2k6's Avatar
may be trying to go further up. i'd try seeing if there's a calibration procedure.
Old Jan 23, 2008 | 05:21 PM
skyhorse's Avatar
i was getting the same thing and found that if I cleaned the rubber surrond really good and it would quit.
Bigd2k6 how much do you in all those mods
Old Jan 23, 2008 | 06:01 PM
str8dum1's Avatar
pretty sure there's a tsb for that. mine does the same thing, but my door is covered in dynamat so the dealer wont touch it.
i'm going to pull the panel and make sure that the track is tight. suspect that's what is making the noise.
Old Jan 25, 2008 | 11:03 PM
bythabay's Avatar
I did this and it seemed to fix the problem (as long as we're talking about the same creaking noise..)
Old Jan 28, 2008 | 05:21 PM
killahb36's Avatar
i get a metal on metal OR glass on metal rattle everytime i go over bumps from the window area. i thought at first it was the seatbelt but it was not. is this the sound you guys get??
Old Jan 28, 2008 | 08:56 PM
chanycrazy's Avatar
dealership will fix it free..
Old Jan 29, 2008 | 02:18 PM
killahb36's Avatar
does anyone have a diy for pulling the door panel on an 05 coupe??? thanks all
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
