audible warning for lights on and key left in ignition not working
Old Dec 30, 2007 | 12:29 PM
PTownG's Avatar
Question audible warning for lights on and key left in ignition not working
I know it was working a few days ago. All of a sudden it's not.
Is there a way to shut it off that I may have inadvertantly done? I would really like it to be working.
Also that button on the back of the drivers seat to make the seat move forward doesn't do anything. Am I missing something or do I need to have it serviced?
06 6MT
Old Dec 30, 2007 | 07:40 PM
PTownG's Avatar
Nevermind. I had the windows tinted a couple days ago. The installer removed the grounding screws in the door switches so the windows wouldn't do their little up and down hop when the doors are opened while the film cures. Car doesn't know the doors are open. Duh.
but thanks for all the replys
Old Dec 30, 2007 | 08:48 PM
vjquan's Avatar
So your doors open/close okay without the window rubbing or hitting the roof side panel?
Old Dec 30, 2007 | 09:40 PM
PTownG's Avatar
Contrary to popular belief the purpose of the window movement is not for clearance, it is to create a tighter seal against wind noise at highway speed. So no.
Old Dec 30, 2007 | 11:38 PM
vjquan's Avatar
Well according to the manual, if you disconnect the battery, they warn you not to close the doors as it may hit and cause damage. How much clearance do you have?
Old Dec 31, 2007 | 12:04 AM
PTownG's Avatar
you're missing the point. with the grounding screws removed the windows don't do the bump up. It doesn't do the increased seal. Screw right next to the contact switch. Easy enough to test. Take it out and you will see.
Old Dec 31, 2007 | 11:57 AM
vjquan's Avatar
When the screw is out, the window is UP! That's why tinters do that, to tint the bottom portion of the glass.
Old Dec 31, 2007 | 04:23 PM
PTownG's Avatar
in that case I guess there is enough clearance although I am still not convinced that they are all the way up
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
