Steering wheel change and vdc off and slip lights on
Old Mar 22, 2008 | 04:40 AM
Xattica's Avatar
Well,
I month ago I changed the Steering wheel. After the install, when I turn on the Car the VDC off and slip lights turns on. When that happends, the left controls of the steering (volume up, down, etc) doesnt work. If I turn on the car and didnt move, and I do not move the steering wheel the lights do not turn on and the controls works ok. What can be?
Old Mar 22, 2008 | 11:52 AM
shipsaeki's Avatar
i think you may have to re calibrate the steering angle sensor at the dealership. or, you could have broken the clock spring windings. I know many people who have done this.
Old Mar 24, 2008 | 02:00 PM
Xattica's Avatar
Thanks.
Where I can found the clock spring windings? That is just the white thin cable or the this includes the black round piece?
Regards.
Old Mar 30, 2008 | 07:40 PM
Xattica's Avatar
Right now the airbag light is blinking...
Old Mar 31, 2008 | 02:54 AM
shipsaeki's Avatar
did you just remove the wheel or did anything else have to be taken out or adjusted to install your steering wheel?
sorry to say, if you broke the windings inside of that round black housing, chances are you will need a new one and have to get it calibrated.
Old Mar 31, 2008 | 07:29 AM
Xattica's Avatar
I remove just 2 airbags screws (Tamper T30) and the center screw (steering wheel). I really don't notice something broke. Then I need to go for service... Any chance that the airbag get open? The airbag signal is blinking likes when you turn on the car, but after the test; still blinking.
Old Apr 2, 2008 | 04:32 PM
Xattica's Avatar
There are any chances that the airbag can be deployed itself? When you said windings, do you referred to the spiral cable?
Old Apr 2, 2008 | 11:09 PM
shipsaeki's Avatar
yes, spiral cable. I would take it to the dealer.
Old Oct 28, 2008 | 09:33 PM
coolbratva's Avatar
I replaced the clockspring today and vdc and slip light went on. I am not sure what to do and I can't think what could have caused this.
Old Oct 30, 2008 | 09:34 AM
elrooko's Avatar
Did you turn the car on while you had the airbag disconnected? If so, you will need to get the SRS code cleared at the dealer, or do it yourself with an Autoenginuity or a Chipher.
Old Aug 5, 2009 | 11:24 PM
IDriveALex's Avatar
sorry to bring this back from the dead, but im having the same problems.
Old Sep 3, 2009 | 02:38 AM
berniEE's Avatar
same me too.
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
