NRG hood shock - where to get replacement end?
Old Aug 3, 2008 | 11:16 AM
elrooko's Avatar
So when my hood shocks bent, it snapped a small piece of my NRG hood shock off. The actual shock is fine but the little metal end that threads onto the shock has a small crack and the pin comes out. I looked on McMaster.com and there are fittings that look just like the NRG ones but I think they maybe too big. Can someone tell me which ones will fit?
Old Aug 3, 2008 | 11:34 AM
SDGenius's Avatar
just call NRG and ask for a new one tell 'em ya just installed it and it came w/that part chipped. they'll replace it for free.
Old Aug 3, 2008 | 09:15 PM
silvernole12's Avatar
I replaced mine with ones from Mcmaster. I got the nylon ones cause my original ones were rusting really bad.
Old Aug 4, 2008 | 01:45 PM
accordfreak's Avatar
i believe it's a m6 thread with 10mm ball socket
Old Aug 4, 2008 | 02:26 PM
elrooko's Avatar
Thanks - can you send me a link to the ones you bought so I can double check the size?
Old Aug 4, 2008 | 02:54 PM
elrooko's Avatar
that's what I was looking for. I ordered 2 of these
since they were about .25 inches longer than the ones on the shock now so I would replace both sides and make them even.
Old Aug 4, 2008 | 03:24 PM
Johnmikins's Avatar
mine are rusted as well...need the link too!
Old Aug 4, 2008 | 04:41 PM
elrooko's Avatar
http://www.mcmaster.com/#catalog/114/1169
If you follow the link, there are 3 types of socket ends. I ordered the 316 stainless steel ones - 10MM ball, M6 threaded end. These shouldn't rust as they are stainless.
Old Aug 4, 2008 | 07:00 PM
I got these.. 9416K86 which are the nylon ones...they look like the stock ones at the ends of the trunk shocks too. Since mine were all rusted they wouldnt come off the ball studs connected to the hood brackets...So I ended up having to completely cut it off and use new Stainless steel ball studs from mcmaster too.
Here are some pics of my setup
It's not as pretty as using the stainless ball ends, but they are easier to remove.
rusty ball and ball socket (couldn't get it apart) with my new stainless ball
Modified stainless ***** with the rusty one
rusty locking pins
Brackets sanded down and holes enlarged to accept the new ball ends
Rustoleum painted satin white brackets
Bracket,socket, and ball at the hood hinge
socket at the fender
all together and working great and rust free
I was little concerned that the bulkier sockets would have some clearance issues but it looks to be all gravy.
Old Aug 4, 2008 | 07:30 PM
Johnmikins's Avatar
Sweet, thanks!
rezendvous420
May 31, 2020 01:26 PM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
atk08
Jul 30, 2015 03:12 PM
cyrus32
Jul 18, 2015 06:22 PM
