Help Tein hood damper?
Old Aug 25, 2008 | 12:00 PM
specialist's Avatar
I can't find a DIY for the tein hood dampers?
I have done a search can find anything? Any one seen one?
Old Aug 25, 2008 | 02:27 PM
RST531's Avatar
here is the thread of it:
https://g35driver.com/forums/body-in...caskyline.html
and heres a vid of it:
http://www.infinitihelp.com/diy/gsed...stallation.htm
Old Aug 25, 2008 | 02:58 PM
specialist's Avatar
that is for his hood damper not for the teins. I think there is a differen't way
Old Aug 25, 2008 | 03:18 PM
specialist's Avatar
i think with the tein you have to remove the batt cover is there a way to use them?
Old Aug 25, 2008 | 09:21 PM
cc_brandon's Avatar
I assume that you are talking about the lack of clearance between the damper and batt cover. All you have to do is use a dremel to cut a small part of the battery cover out to give the damper enough clearance. It should come out looking like the pic below from speedraver's DIY.
Old Aug 27, 2008 | 01:30 AM
specialist's Avatar
Oh That will not work with the teins but thank anyways
Old Aug 27, 2008 | 02:29 AM
RST531's Avatar
well i searched lots of places and cant find any installed pix of teins on a g35. other cars but not a g35. can u post a pix to see how much different they are compared to the nrg hoodshocks?
Old Oct 17, 2008 | 01:17 PM
reverse's Avatar
Just installed mine, u can't use the battery cover at all! (sux) it bumps against the hole where the cover is screwed in at the front. the teins don't hook up on the fender edge either.
Old Oct 17, 2008 | 01:27 PM
RST531's Avatar
can u take a pix.
Old Nov 11, 2008 | 10:25 PM
lmSteveO's Avatar
I have the Tien Dampers...but there for the 350z someone said that they are the same. Looking at them there different from the NRG's they are flaring out from the top and going in at the base or the bottom.. it opens and closes but I have to lift it all the way and then it will stay as well as it studders as it goes up and down..like its not smooth...I got them for free and used soo im not b*itching..can anyone see if im doing it right..i read the install paper..and this is what it shouldbe....
thanks
Old Nov 12, 2008 | 09:54 AM
reverse's Avatar
<a href="http://imageshack.us"><img src="http://img505.imageshack.us/img505/4568/1112080746gg6.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img505/1112080746gg6.jpg/1/"><img src="http://img505.imageshack.us/img505/1112080746gg6.jpg/1/w480.png" border="0"></a>
<a href="http://imageshack.us"><img src="http://img352.imageshack.us/img352/7215/1112080746amz5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img352/1112080746amz5.jpg/1/"><img src="http://img352.imageshack.us/img352/1112080746amz5.jpg/1/w480.png" border="0"></a>
<a href="http://imageshack.us"><img src="http://img204.imageshack.us/img204/4455/1112080747awl8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img204/1112080747awl8.jpg/1/"><img src="http://img204.imageshack.us/img204/1112080747awl8.jpg/1/w480.png" border="0"></a>
<a href="http://imageshack.us"><img src="http://img253.imageshack.us/img253/8171/1112080747ib8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img253/1112080747ib8.jpg/1/"><img src="http://img253.imageshack.us/img253/1112080747ib8.jpg/1/w480.png" border="0"></a>
Old Nov 12, 2008 | 06:12 PM
specialist's Avatar
i guess you can put your covers on?
Old Nov 13, 2008 | 09:08 AM
reverse's Avatar
Nope, they bump against the dampers. so potna thats going to try to modify them so they will fit.
KruZZe
Feb 27, 2023 05:04 PM
Picture Share
Feb 4, 2018 12:41 PM
hrdwirk1
Oct 2, 2015 06:34 PM
