How do I take APART my Tail lights ???
Old Mar 16, 2009 | 11:17 PM
V35_Gcoupe's Avatar
I know you can bake open the headlights on our cars, but I can't figure out how to open up the taillights. I've unscrewed everything and I cannot see any silicone holding it together.... I'm basically trying to paint my tails exactly the same way one would paint their headlights.
So are there hidden screws somewhere, or what ?? I tried baking them open but it didnt work, wouldnt budge at all....... anybody know anything about this ?
(in case anybody is wondering, I'm trying to open my tails so I can paint black the chrome bezel that's inside... this way it will give it a tinted look while the plastic on the outside will still retain it's nice glossy red color. I'm hoping it will look nicer than tail overlays, everyone has those I wanted to do something a bit different)
Old Mar 16, 2009 | 11:32 PM
Blackmouf's Avatar
I can't find the thread but there is one on this forum where someone has done this. It looked good. I believe he had to cut open the tail lights along the seam because you can't bake them.
LEON NYC's Avatar
I heard horror stories, i dont think its as easy as the headlights, contact x-vert (180 custom) maybe you can ship it to him
Old Mar 16, 2009 | 11:35 PM
V35_Gcoupe's Avatar
yes actually I had an exacto knife in my hand earlier today eyeing the seam... but I wanted to post here first and see if anybody knew any better...
horror stories as in ?? I've got a spare set of tails, so I plan on doing them first to get a grip on how to do it, then do my actual lights that are going on my car... so I think I'm covering my bases hopefully
Old Mar 16, 2009 | 11:38 PM
DrewTheSuit's Avatar
yep cut em...dremel is your friend
Old Mar 16, 2009 | 11:43 PM
V35_Gcoupe's Avatar
how would I seal them back up ? plain sticky silicone ?? would that be enough to hold them together ?
Old Mar 16, 2009 | 11:46 PM
Deftronix's Avatar
Dremel and JB weld should do the trick. I dont think an exacto knife will do the job. Good luck!
Old Mar 16, 2009 | 11:49 PM
V35_Gcoupe's Avatar
hmmm.... ok I got my trusty dremel in the garage, just gotta buy the right cutting bits.
wow, that JB weld stuff sounds like supershlt, I'm definitely using that..
http://www.jbweld.net/products/jbweld.php
thanks guys, I'll post finished results when done
Old Mar 16, 2009 | 11:50 PM
01msmis's Avatar
yea, you will have to dremel the tail lights. i did it that for is300, and silicone to seal it. I dont think you should do it to the G, because our lens are red. you cant really tell the different unless you park next to another G. it not worth it unless you can seal the tail light with silicone really well. Silicone is really messy and can look bad if you dont do it right
well good luck with your project!
Old Mar 17, 2009 | 11:03 AM
MidnightG35X's Avatar
Dremel with a diamond cutting wheel to open it, I use a 5 minute epoxy from loctite to seal them back up.
Old Mar 17, 2009 | 01:00 PM
RST531's Avatar
Irockag35 did that mod. here is a link to his thread. there are a few pixs in there, but no comparison pixs. link below.
https://g35driver.com/forums/exterio...il-lights.html
Old Mar 17, 2009 | 09:30 PM
V35_Gcoupe's Avatar
^ thanks for the link, it looks just like I imagined....
just got home, I'm sitting here about to dremel away with the heavy duty cutters.... I was looking at the diamond cutter as well but got these instead.... I'll try it out on my spare set of tails, if it's not a smooth cut I'll go back to Home Depot get a diamond wheel...
thanks guys
Old Mar 17, 2009 | 10:03 PM
IrockAG35's Avatar
Ohio G Club moderator
heres a thread i made last yr i painted mine and they came out great but its hardly worth the time and effort..good luck
https://g35driver.com/forums/body-in...ot-lenses.html
Old Mar 18, 2009 | 02:43 AM
V35_Gcoupe's Avatar
^ thanks for the link, yea you're totally right... I managed to get one open and decided I'm not gonna go through with it.... instead I've taken out the tail LED's and I'm gonna do some led work around the front of the car...
Old Mar 18, 2009 | 03:55 PM
IrockAG35's Avatar
post some pics up when you complete your project..GL
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
