Authentic NISMO Bumper
Old Oct 26, 2010 | 09:43 PM
  #32
Xet's Avatar
Xet
Originally Posted by GarGamel
its not the shop, the bumper was made wrong on one side, it was alittle shorter and of course you can't tell until it was put onto the car (defective bumper??).
nothing the shop can do unless he wanted to use bondo and mold it onto the car.
You should post in the your regional section and see where fellow members have found to be good quality shops.
Old Oct 26, 2010 | 10:39 PM
  #33
felixsc300's Avatar
Originally Posted by Dustin@StrafeAutomotive
When u said you couldn't tell before it was put on...did this shop test fit the bumper prior to paint/prep etc...? If so they shoulda seen and then modified accoringly... not knockinthe. Shop,just asking...
Agreed. It's still your buddy's fault for failing to request a test-fit before they painted and installed. Many body shops are in the business to make money, not make sure you're happy with aftermarket fitment on X part.
Old Oct 26, 2010 | 10:48 PM
  #34
walshtj's Avatar
As calvin said, you can buy from any vendor and get great fitment. Its all about the prep work and install....
Old Nov 1, 2010 | 11:16 AM
  #35
Ray@OCInfiniti's Avatar
I still have connections for the deepest discounted prices for all authentic nismo parts, shoot me a pm
Old Nov 2, 2010 | 10:27 AM
  #36
Tim@Grubbs's Avatar
We get these parts direct from NISMO. No connections to go through here!
Feel free to contact us with any questions.
Old Nov 8, 2010 | 12:40 PM
  #37
same here I'm direct with Nismo
Old Nov 8, 2010 | 05:27 PM
  #38
JZ's Avatar
JZ
G35 Coupe KY0
its all about the shop that will fit the bumper... I bought my last bumper from a vendor that had good rep for fitment but if that was true, so much work needed to be done to it so it can fit, not counting the work to make it line up to bolt it on at least... but after a lot of hard work and dedication the shop and I got it done. I hate sanding FG and using FG to mold and reconfigure bumpers, i also filled my corner lights in. If you want authentic, go authentic, if you want replica, then contact the vendors or check their threads for complaints regarding fitment issues, simple as that
Old Nov 8, 2010 | 05:30 PM
  #39
Tim@Grubbs's Avatar
Well said, JZ.
Still on the lookout for an order from you.....since you have that coupon and all.
Picture Share
Feb 4, 2018 12:41 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
