Hood, fender rub....
Old Nov 9, 2010 | 07:08 PM
CJunemann's Avatar
Anyone else have this issue? Ive seen it on mine and one more.... Its getting worse and worse..... fender and hood are already bending....
Old Nov 9, 2010 | 07:20 PM
CandlestickPark's Avatar
ill Sedan
Your fender and hood are rubbing on what exactly? Do you have any pics?
Old Nov 9, 2010 | 07:37 PM
CJunemann's Avatar
and its JUST the passenger side, drivers has no problem.
Old Nov 9, 2010 | 07:45 PM
SkylineGTR2789's Avatar
i have the same problem but not as bad .. i think the oem hinges are going bad
Old Nov 9, 2010 | 07:47 PM
CJunemann's Avatar
wtf? Hinges you say? Damn these crazy Infiniti problems... lol
This car is great, and would buy again if given the chance, but we have some odd ball issues lol
Old Nov 9, 2010 | 07:55 PM
Stryde's Avatar
Same thing has happened to me before, man...passenger side. The hinges need to be greased up every so often. I just do a few quick blasts of silicone spray a couple times of year and it hasn't happened since.
I imagine hood dampers would help keep this from happening too.
Old Nov 9, 2010 | 07:58 PM
couple you post a DIY ? lol
Old Nov 9, 2010 | 08:00 PM
Heist.'s Avatar
spray some WD on the hinge bracket a few times a year and you should be ok. Thats really bad buy some new hinges.
Old Nov 9, 2010 | 08:07 PM
Stryde's Avatar
I don't have any pics of the process, but it's extremely simple -- easy as greasing a squeaky door hinge in your home. Just get some WD-40 or silicone spray (or your favorite lubricant...no homo), and use it one the hinge pivot points.
Old Nov 9, 2010 | 08:08 PM
Swivel's Avatar
Moderator
Lithium-based spray grease works well and will last far longer than silicone or WD.
Old Nov 9, 2010 | 08:39 PM
I sprayed my hinges with WD-40 and it didnt help .. the hood still opens too closely to the fender, maybe im doing it wrong ?
Old Nov 10, 2010 | 12:08 PM
B T's Avatar
B T
it's already bent, replace the hinges and properly lubricate them before they do any additional damage.
Old Nov 10, 2010 | 12:54 PM
jimmyc13's Avatar
+1 I simply used WD-40 4-5 years ago and the problem has not occurred since.
Old Nov 10, 2010 | 01:01 PM
B T's Avatar
B T
I tried WD-40 and White lithium grease, RESULT: broken hood hinge
Once the the hinge has bent and the structural integrity of the hinge is compromised, it may continue bending even with proper lubrication causing the fender/hood damage and leading to eventual failure. I'm not saying this will happen to you necessarily, it all depends on how bad off your hinges already are.
Old Nov 10, 2010 | 01:03 PM
Swivel's Avatar
Moderator
^^ Yup, if you can loosen it up and it's not bent, you're fine, otherwise no amount of lube will straighten a bent hinge.
