$5 dollar actuator fix!!!! (Krazematik verison)
Old Oct 2, 2012 | 10:27 PM
krazematik's Avatar
first i would like to thank JFpound for the write up now im going to post some of my pictures for those who have concern
tools need for the job metal bar at the bottom was not used, its basically its screws small "L" brackets and a drill with drill bit
first remove a small cover at the door handle with a screw behind it
now remove a the cover at the door handle
now once that is removed there should be two screw behind it
use a dremel to drill out the top part inside the door handle the yellow arrow shows what need to be shaved down
how remove the door speakers and behind it should be a few wires but the main ones are "blue" not baby blue and the other one is purple those are the two wire that will need to be tapped in
how make sure you line the up the rod then drill threw the white plastic and grey door handle, make sure you drill and make a big hole for any adjustment or room to play with now the rod that came with the kit will need to be cut down to fit
how this is how it suppose to look like
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
master111
Oct 6, 2015 01:36 AM
NyCrAzY
Oct 1, 2015 09:19 AM
