Turn Signal / Hazzard light issue! Any help is great!
Old Feb 9, 2016 | 11:23 PM
Homamk's Avatar
Hey guys.. i just bought my first 04 g35 coupe automatic .. the guy i bought from never shared that the car had an issue with the signal lights/hazzards. So here is my issue. When i use ANY signal, all my rear lights start flashing together (basically hazard lights) but it includes my brake lights as well. Hazards kinda do the same thing. The front signals fine. Just the rear. I dont know what can cause this.. or where to start. Iv looked and looked and i got nothing and very new to these cars. Im uploading a video as we speak but until than any ideas would be great. I did see that there is a kit you buy to make your brake led lights be used as signals. Is it possible someone tried to install this and messed up? Siggestions or places to start trouble shooting would be great. May take me a while (snowy and cold in PA) but any help is appreciated
Thanks
Link to video
Old Feb 10, 2016 | 12:47 AM
hurleyguys's Avatar
well i guess i would take the rear lights off and make sure the wires look intact and that nothing is spliced into the lines.
also i would check your grounds. bad grounds have made other cars i have worked on do some crazy ****.
Old Feb 10, 2016 | 01:35 AM
deeliciousqueen's Avatar
G35 coupe 6mt
I second hurley, I immediately thought that a harness mod from diode dynamics or something similar is plugged in the rear led wiring. Pry out the plastic cover and inspect the wiring.
Old Feb 10, 2016 | 03:39 PM
Homamk's Avatar
It doesnt look like there is anything connected to the tail light harness : ( see attached pictures. Any other recommendations or suggestions would be much appreciated. Im very lost.
Attached Thumbnails Turn Signal / Hazzard light issue! Any help is great!-20160210_124427.jpg   Turn Signal / Hazzard light issue! Any help is great!-20160210_124415.jpg
Old Feb 10, 2016 | 10:07 PM
Homamk's Avatar
Well i cant figure this out. From what i can tell.. something has been done to the car to get the brake lights to flash. I dont think that is standard for these cars. The brake lights never flash during hazard or signal light. However, nothing is connected to the harness of the tail lights. Im at a total loss. There was a relay in the trunk but when i unplugged it.. nothing changed. Any suggestions help? Completely lost. I cant drive the car because of this.
Old Feb 11, 2016 | 01:40 AM
coffeysm's Avatar
Maybe your BCM is hosed?
Old Feb 12, 2016 | 05:53 PM
Homamk's Avatar
That sucks! Would everything act normal except for just this one thing. Also, the front lights work as they are supposed to. Its just the rear. And seeing the led brake light blink, it makes me think some sort of mod was added to do that, it was just wired wrong. I dont think its normal for led brake lights to blink. Dam. This sucks.
Old Feb 14, 2016 | 08:47 PM
Homamk's Avatar
Bump?
Old Feb 14, 2016 | 10:17 PM
coffeysm's Avatar
Originally Posted by Homamk
Bump?
Yea, certain things can work completely normal and other things get fubared. You'll need a wiring diagram and check for power from BCM to lights. Then check wiring continuity to make sure the wiring is good. There are some ground connects as well that can cause issues I think. There is a couple of fuses I think also. Look for the FSM at thenismoclub.com and start from there.
If you do need a BCM you'll have to go to the dealer to have your keys reprogrammed.
Old Dec 31, 2016 | 07:39 PM
Z32_nation's Avatar
Did u fix it
Did u manage to fix this problem if so what caused the issue? Thnks
SxExCx
Accessories-Vendor
58
Jun 27, 2018 07:26 PM
Alexg_35
Jan 14, 2017 11:02 AM
Richie8
Feb 9, 2016 08:58 PM
MustangInfiniti
Dec 11, 2015 09:33 AM
LowG35Life
Nov 25, 2015 04:24 PM
