Clear coat chemical burn
Old Apr 30, 2017 | 08:15 PM
Hydranix's Avatar
So my 06 G35 sedan has a several spots on the passenger side rear door, a spot on the driver side front fender, and some small spots on the hood of what looks like some kind of chemical burn.
They look as if something splattered the car and ran a bit eating up and damaging the clear coat in the process.
Light wet sanding made no difference, and if anything made it looks worse.
Polishing did nothing, and I'm a bit lost at where to go from here.
I'm not interested in repainting or applying a new clear coat, there's currently a huge dent near the rear passenger-side fender from a lady backing into me, and until it's fixed, I just want to find a way to made these spots less ugly.
Some images:
Largest of the spots, this was the only one I attempted any kind of polishing or wet sanding, which made a slight difference, but started to make it looks worse.
Spoiler
Closer look at the spot, shows what appears to be flaking clear coat?
Spoiler
Another angle showing the rough texture of the spot. It is rough to the touch, and sanding did not make it any less rough.
Spoiler
Microscope image of the spot showing it's off texture. This is very high magnification.
Spoiler
This is spot on the front fender at moderately high magnification
Spoiler
This is a shot of the hood spot at moderately high magnification
Spoiler
Old May 7, 2017 | 07:36 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Looks to me like the clear is etched too deeply to remove. And you are very limited with factory clear how much you can wet sand (about .5 mil) before losing the UV protection. If wet sanding and polishing aren't working at all, your only choice is a respray.
Old May 7, 2017 | 08:38 PM
gary c's Avatar
There are several things you could try, bottom line once the clear coat begins to fail there very little you can do except reshoot...sorry!
Gary
digital sol
May 5, 2014 03:03 PM
kenempireex
Jan 12, 2010 11:44 AM
Polishthrust
Mar 1, 2006 06:24 PM
Silverbolt
Feb 13, 2006 04:12 PM
JKDman
Jul 14, 2004 01:31 AM
