Window Issue
Old Jun 9, 2019 | 08:24 PM
G35stephen's Avatar
Window Issue
2006 G35 Coupe.
I have a weird issue that I couldn’t find any answers to, maybe someone can help me!
Roll the window up fully.
- turn car off, window still up.
- open door, window still up.
- close door, window rolls all the way down.
Roll the window up fully, then tap down 1/4”.
- close door, window still up.
Im not sure what to do!
thank you!
Old Jun 9, 2019 | 08:46 PM
Scorpi0's Avatar
Theres a reset button on the window motor u will need to access. Then do the reset procedure:
https://www.infinitihelp.com/diy/gco..._procedure.php
Old Jun 9, 2019 | 09:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If the window recalibration won't work then it's time for a new window motor, this is a common problem and you're experiencing all the classic symptoms. Usually the window recalibration will be good for another year or two though.
Old Jun 9, 2019 | 09:19 PM
G35stephen's Avatar
Understood, thank you both! I did see the recalibration, wasn’t sure if it would work since everyone else’s symptoms seem to be a little different. I’ll let y’all know!
Old Jun 9, 2019 | 10:54 PM
cleric670's Avatar
BANNED!!!
My driver window had the same problem you're experiencing about 2 years ago and a recalibration worked, I still haven't had to replace it. Passenger window however only held for about 6 months before the recal would no longer help so I replaced it.
Jojo4787
Oct 2, 2018 10:09 AM
LaserRedG35VS
May 20, 2015 12:40 PM
idrive_MD
Lighting
Dec 10, 2010 10:52 PM
weezzerr
19
May 8, 2009 12:22 PM
willcho415
Drivetrain
Apr 16, 2009 01:59 PM
