Window won't go up or down
Hello,
A few days ago I was taking apart my radio and noticed that the passenger window won't roll up or down using the interior switches. Both driver and passenger switches don't work but they do light up so I assume they have power. The driver side window rolls up and down just fine. I know that the window motors are a common problem on the g35s but the motor is just fine since I can roll the passenger window up and down using the keyfob just fine. It's just the interior door window switches that don't work. I have taken my radio apart many times and never had this issue. I assumed that I may have disconnected some kind of a connecter but after putting everything together it still doesn't work. The window still won't go up or down from the inside. I can only roll it up and down from the outside using the keyfob or the door lock.
I tried googling this issue but didn't find anything.
Thank you in advance!
Make sure you didn’t bump the push button switch on there that keeps anyone from moving the window up or down.
is it still dropping when you open the door and raising when you shut it?
It's possible that either the driver's master switch or passenger window switch circuit board has failed in some way. @Cleric670 can probably chime in on how to test for a bad switch with a multi-meter. I can't. That electricity stuff is still a magical dark art to me....
I feel like an idiot but that was the problem. I just accidentally bumped the push button switch. I swear I thought I checked that already
Thanks tho
Thanks tho
