Reverse Tilt Down Outside Mirrors
#198
Originally Posted by GEVO
If you go to the KP Technologies site they are working on this module for the G coupe. My Caddy CTS had this and I miss it on the G.
GEVO
http://www.kptechnologies.com/
GEVO
Anyone know why this and the sunroof module would only work on a coupe?
#199
The tilt down module is universal and should work on almost any car with power windows.
Despite the fact that both the coupe and sedan are G35s there are some pretty significant electrical differences between them. For example, the coupe sunroof switches switch a (-) signal whereas the sedan switches a (+) signal. Also, the coupe 'cluster matrix' is a positive signal, whereas the sedan is negative.
You would think, to save costs, that they would use the same sunroof and BCM controllers in both, but they didn't.
#202
#204
#206
Originally Posted by KPierson
I've got the new version in my car now, and it's working great. I have a couple updates to make to the software then it will be ready to start testing.
#207
#208
