Please Help, Struggling to finish DIY for Seat Gear
Old Dec 2, 2010 | 04:36 PM
sprasad03's Avatar
Hey guys,
I have been following this: http://www.odometergears.com/subpage...ar_How_To.html
So this is what happened I replaced the gear and put everything back on, then i noticed I forgot to put the bolt back on to hold the gear. So when i dismantled it again, and it took off the motor off the gear it was stuck, i pulled it off and this ring bolt was stuck. I got it off but i looked inside the motor circle, the ring definitely was in it so I took the ring and put it back at the very end of the motor inside.
I put the securing bolt back on the screw gear and made it as tight as possible (I assume this is correct). I tried to slide the motor back on to the gear screw and it wont slide all the way on the screw. I dont know what is wrong and I followed the steps. It doesnt look like anything is blocking it so I cant figure it out.
I know it was just the gear to causing the problems but now I cant fix what I already fixed ...........
AT23
Sep 15, 2015 07:44 PM
zcherub
Sep 10, 2015 12:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
pasjr1972
Sep 1, 2015 10:17 PM
