BOTH power door locks and power trunk release not working
Old Mar 29, 2020 | 05:24 PM
Rainy's Avatar
2005 G35 Coupe loaded but bone stock!
Hey guys so I bought my car like this and am finally getting time to try and work on all the little things it needs.
Both power door locks do not work - no clicking in the door panel, they dont work with keyless OR the door switch. My gas cover works properly and is the only thing that makes noise when I hit the lock/unlock switches.
Also, the power trunk pop doesnt work and the previous owner rigged up a rope to pull to pop the trunk via the emergency release. It works but i would obviously like to fix it.
Are these things related? I've read the trunk has no fuse associated with it and commonly the wire breaks off on the grommet in the trunk metal area on the top passenger side. As for the door locks is there a relay/fuse it could be? It's odd both dont work.
Old Mar 29, 2020 | 06:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
First verify they have power, fusible link holder section F, 50 amp. Then to the Fuse Block - J/B, the cabin fuse block. If you have the regular key system 18 will have a 10 amp, if you have the intelligent key (keyless start) then 21 will have a 10 amp. Also fusible link 33 will have a 15 amp.
Typically what happens is the wires break in the trunk flexible conduit and ground out, blow the fuse, and it stops working.
Old Mar 29, 2020 | 06:19 PM
cleric670's Avatar
BANNED!!!
Since they don't work with either the fob or the switch that's what makes me think you blew a fuse.
Old Mar 29, 2020 | 10:31 PM
Rainy's Avatar
Just want to say thanks Cleric for always helping out in my threads. You've always got a quality response and I really appreciate it man!
twithers
Dec 5, 2018 03:14 PM
treacherous
Mar 27, 2011 08:38 PM
kidd_drastic
Jun 23, 2010 12:04 PM
donr
Mar 30, 2010 11:22 AM
italianguy22
May 25, 2009 07:44 PM
