Driver Seat wont tilt backwards
Old Mar 26, 2022 | 12:29 AM
04vq35sdn's Avatar
2004 G35 Sedan 6MT
Exclamation Driver Seat wont tilt backwards
I can't get my driver-side front seat to tilt backward. It can move back and forth and tilt forwards but not back. I used to be able to use the memory button to move the seat all the way back and tilted back and then just adjust it forward but now that does not work unless I forgot how to do that and it's more than just pressing the button. I'm curious if anyone knows how to bypass the switch and move the seat manually or with wires, any advice is appreciated. thanks
Old Apr 2, 2022 | 09:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's likely the motor failed, unplug it's harness and measure for voltage when operating the switch.
Old Apr 3, 2022 | 08:29 AM
jbarnett250's Avatar
my money is on a bad switch. tilt forward uses same motor as tilt rearward, right? my switches went bad too. I had to buy a used set on ebay.
humbalum
Nov 26, 2021 11:51 AM
rodneyc8063
Mar 24, 2013 11:36 AM
G35REVUP
Sep 13, 2012 06:44 PM
specialist
Interior
May 10, 2009 07:46 AM
