Headlight Problem! Please HELP!
Old Oct 3, 2006 | 03:50 AM
darithS's Avatar
One of the bulbs in the headlight went out and I was looking for it to replace it but I don't know where its at, anyone know how to fix this... its this light -
Old Oct 3, 2006 | 09:50 AM
Calvin's Avatar
Overglorified Altima
thats the clearance strip. uses a 194/168 (194 and 168 are the same thing) bulb. im pretty sure you dont have to take the housing out for this, you can just channge it like you would change any other bulb.
Old Oct 3, 2006 | 10:15 AM
GR8TG35's Avatar
First, Welcome to the board!
In order to change out that bulb (clearance strip), some say they can get their hand in from the engine compartment. Myself, I think its almost impossible.
You will need to turn the front wheel in so you can access the wheel well area, then jack that side up some so you can remove the fastner/plugs (5 of them is all you need to remove, a couple on the top and on the outside edge), and the one little phillips screw on the inside lip of the fender.
Once you remove all the fastners and the phillips screw, you can peel the plastic wheel well liner down and have access to the back of the headlight assembly. You will see a black/red wire up in the right corner of the headlight assembly. It will have a long black plastic tab you can twist to remove the socket/bulb. replace the bulb and reinsert the socket.
Then reverse the process, and you should be good to go.
Try to remember the position of the socket when you remove it. It only seems to go back in one way......it will make your life a whole lot easier.
Good luck......and if you plan to use aftermarket bulbs, be prepared to do this often. I have had to replace the bulbs on both sides a couple of times already, once because the coating peeled of and it looked like $hit.
Old Oct 3, 2006 | 10:18 AM
MixturePinoy's Avatar
I wish the strip looked more attractive at night. IMO it looks like it was cheaply engineered
Old Oct 3, 2006 | 10:26 AM
Calvin's Avatar
^^have you tried changing to pure whites for the clearance strip? looks much better imo
Old Oct 3, 2006 | 10:50 AM
^^ I've seen it before and i still don't feel it. I would like to go multiple led's all the way down. I think that would look better. kinda like the new caddy's
Old Oct 3, 2006 | 04:43 PM
darithS's Avatar
cool thanks guys
Old May 6, 2010 | 09:23 PM
or_G's Avatar
If I got aftermarket bulbs, will I need a new ballast??
wonderizm
Sep 24, 2015 03:09 AM
derres
Aug 28, 2015 03:27 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
Mick_L
Aug 25, 2015 04:27 PM
attarday
Jul 15, 2015 04:03 PM
