Clearance bulb replacement
Old Jun 28, 2007 | 04:19 PM
whyjay91's Avatar
I did a search and read through many threads regarding replacing my clearance strip bulb (it went out). All I could find was information on the fact that I had to either remove my wheel, bumper, and/or inner wheel well liner.
I was about to remove the wheel when I found that you can simply pull the two bolts on the hood-switch bracket and move it aside. At which point you can get to the clearance bulb and it looks like you can get to the headlight as well. This is on both sides. It's a bit cramped but for average hands (no meat-hooks) you can get to them with only minor pain.
The fog light and amber parking light look like they will require removal of the inner fender lining.
Just thought I'd post my recent experience.
Old Jun 28, 2007 | 04:52 PM
sfgr415's Avatar
What part is the "hood-switch bracket" you speak of?
Old Jun 29, 2007 | 12:45 PM
whyjay91's Avatar
The hood switch... is the only switch triggered when you open and close your hood. It's on the passenger side, toward the front of the vehicle, in the engine bay. It looks like a plastic-wrapped spring, of sorts, and is held in place by a metal bracket.
Old Jun 29, 2007 | 12:49 PM
sfgr415's Avatar
Oh. I see what your saying. The hood pin-switch. Thanks.
Old Jul 1, 2007 | 11:44 AM
chrispyy's Avatar
wow, i was about to take off my whole bumper and everything to replace my side strip. do u think u can take pictures for us to see? i dont want to go through the trouble of taking off my bumper. thanks man i would really appreciate it.
Old Jul 2, 2007 | 07:27 PM
whyjay91's Avatar
I'll try and snap some pics tonight. But it's pretty easy though. Just look in the engine bay where you think the clearance bulb socket should be and you'll see it (get a flashlight). It's a long, tabbed bulb socket that is flat, black, and plastic. You can't miss it.
Old Jul 2, 2007 | 07:36 PM
sfgr415's Avatar
it's pretty much at the top corner of the headlight.
Old Mar 1, 2008 | 05:27 AM
GeeCoupe's Avatar
pics please
Old Mar 17, 2008 | 06:02 PM
thechronic's Avatar
this does not work for the clearance bulb or the headlight
Old Apr 20, 2008 | 05:33 PM
brisk's Avatar
so wait...we don't have to remove the wheel well?
so do i just remove the two bolts and then what?
it seems like the plastic is pretty sturdy and doesn't look like it will bend...
Old Apr 21, 2008 | 09:17 PM
thechronic's Avatar
once again...this does not work. i tried it.
Old Mar 6, 2009 | 10:54 AM
DiGil's Avatar
Bringing this back from the dead. I'm at work and can't go out and peek in my engine bay, but can anyone confirm that this works to replace the clearance strip bulb?
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
EasySausage
Jul 20, 2015 03:56 PM
Ashton35
Jul 17, 2015 10:11 AM
attarday
Jul 15, 2015 04:03 PM
