quick question about stock lights
Old Oct 10, 2007 | 11:30 AM
surfquikslver's Avatar
i have an 04' g35 coupe..
Im pretty sure there HID'S i wanted to get some 6000k or 8000k bulbs for them but i wasnt sure if its a direct replacement or not like it was on my bmw. Also if they are hid's what tempature are they stock?
thanks!
Old Oct 10, 2007 | 11:37 AM
patman530's Avatar
Stock is 4100K. I would stay away from 8000K, the light output and quality of these bulbs will be crappy. If you want a good replacement try the Philips Ultinon 6000K D2R or PIAA 6600K D2R. These will be direct replacements.
Old Oct 10, 2007 | 11:50 AM
MixturePinoy's Avatar
Any D2R bulb will be a direct replacement. . . the higher in the kelvin scale you go, the lesser the output.
Old Oct 10, 2007 | 04:18 PM
thanks guys.. i think im gonna go with the 6000k philips bulbs.
Old Oct 10, 2007 | 04:39 PM
redlude97's Avatar
Just know you'll be losing 25+% of your stock output
Old Oct 14, 2007 | 03:33 AM
jalilig35's Avatar
so the higher the kelvin the less in brightness of the light?
Old Oct 14, 2007 | 02:10 PM
redlude97's Avatar
Yes, by a significant amount
Old Oct 14, 2007 | 02:40 PM
Joaquin03's Avatar
Staff ALUMNI
i thought 6000k had only a slight loss in brightness, not 25%??? that seems a like alot for a 1800K difference. i'm not going to do doubt redlude because he knows his stuff but i can just imagine the kind of light output i'd be losing or someone else would be losing when deciding to go with 8 or 10000k or more....
Old Oct 14, 2007 | 02:59 PM
MIA BlazinVQ's Avatar
brb getting cut
Actually, a 3200 lumen to a 2800 lumen decrease is roughly a 13-14% loss, so it's not that bad a loss when going up to 6K's
Old Oct 14, 2007 | 05:03 PM
redlude97's Avatar
Except Phillips ultinon 6000k d2r ~2200-2400 lumens, not 2800 lumens, so 3200 to 2400 is a 25% loss
Old Oct 14, 2007 | 05:08 PM
brb getting cut
^not that it matters, but what's your source? i know the internet isn't always as reliable as
it seems, but several websites say 2800 lumens
Old Oct 14, 2007 | 05:27 PM
redlude97's Avatar
Here is a Philips ultinon "6000k" d2s bulb spec sheet, remeber the ceramic shielding on a d2r bulb cuts the output by 2-300 lumens
2400 lumens is the best case output of a d2r ultinon bulb, it can be as low as ~1800 lumens
Old Oct 14, 2007 | 07:52 PM
Joaquin03's Avatar
Staff ALUMNI
so let me get this right.. if you were to do a full Quad Bi-xenon setup (like redlude is about to do) what would YOU put on YOURS???
and if answer was not 6000k then why not??? are you going for output, color, both??
Old Oct 14, 2007 | 08:35 PM
brb getting cut
i don't know who this question is directed to, but if it's for me, then I already have 6000K ultinons. I wanted a good compromise b/w aesthetics and output,
and 6000K was a good compromise
P.S. good find on the spec sheet 'lude, finally something that 'looks' legit
Old Oct 14, 2007 | 08:47 PM
Joaquin03's Avatar
Staff ALUMNI
for whoever.... thanks for the insight
