Changing the Step / Courtesy Light
Old Jan 7, 2008 | 11:51 PM
Mr Inkredibul's Avatar
Anyone know how to change the step light? Or where to get bulb bulb type DE3022 that is bright white like VLED's? I can't find anytime type of guide!
Old Jan 8, 2008 | 12:07 AM
escobar929's Avatar
i have piaa bulbs T6, been running the same bulbs for almost three years. hate the vleds, tried switching to them and they lasted 2 weeks. so i put the old piaa back in there
very easy to change, just use a small knife or screwdriver and cover it w/ a cloth so you dont damage anything. then pop out from one of the corners of the plastic housing so the the whole light comes loose. then you have access to the bulb
Old Jan 8, 2008 | 09:44 AM
Anyone else have a bad experience with VLEDs? And what VLED bulb is it?
Old Jan 8, 2008 | 11:02 AM
Sportcoupe35's Avatar
Yeh peice of cake to change. I put these LEDs in mine...I forget where I got them....they look nice though.
Old Jan 8, 2008 | 11:05 AM
Do you remember the bulb size on the LEDs?
Old Jan 9, 2008 | 01:50 PM
VLED Bulb size for Step light? Anyone know?
Old Jan 9, 2008 | 03:05 PM
sfgr415's Avatar
There is SO MUCH info available about LED replacements for interiors lights. I probaby have posted the info at least 10 times.
Anyways,
If they step light you are talking about is the light under the door, then it is the same as the dome light, a 31mm Festoon bulb.
I am running VLED 9-LED white bulbs. Have had them for a long time now and no issues at all.
Old Jan 9, 2008 | 03:13 PM
Thanks so much. The search results didn't yield any info I was looking for but this helps a lot!
mjfenix
Jul 24, 2015 05:16 PM
ClwMike
Jul 23, 2015 12:55 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
