LED 'em up! 56k = PC hang
Old Nov 7, 2008 | 08:51 PM
  #61
Dranom's Avatar
Originally Posted by kala1
Can Anyone tell me what that little bulb is called in the fog light And what size it is PLEASE
Please refer to the first post i made. Answer to ur Qs is there
Old Nov 10, 2008 | 02:33 AM
  #62
DrewTheSuit's Avatar
can you explain how you modded the vanity lights? your first post said they didn't quite fit
Old Nov 10, 2008 | 03:13 AM
  #63
Dranom's Avatar
yeah it doesnt fit coz the vanity that VLEDS sells are a bit long. you need to cut the plastic inside to make it fit. You just need to be patient w/ it.
Old Nov 10, 2008 | 07:26 PM
  #64
got your PM...thanks again, now just waiting on shipping
Old Nov 11, 2008 | 01:18 AM
  #65
Dranom's Avatar
your welcome!
just be careful w/ the white plastic some the vanity! its a bit fragile
Old Nov 14, 2008 | 04:23 PM
  #66
codeflux's Avatar
how do you remove the Upper storage box bulb? I got the plastic cover off, but i can't pull the bulb...
Old Nov 14, 2008 | 04:34 PM
  #67
Dranom's Avatar
for the coupe i remove the plastic on top of the glove box and then reach for the bulb. If i recall you need to twist it to unlock
If you still cant get it out ill take a pic of mine to show you
Old Nov 14, 2008 | 04:40 PM
  #68
codeflux's Avatar
thanks! i did twist it about 30% CCW, but the bulb still didn't want to come out. i tried grabbing it with tweezers, and that didn't work. will try again tonight.
i was afraid the plastic part of the socket that was twisted to unlock it is going to fall in, along with the bulb. can that happen?
Old Nov 14, 2008 | 08:24 PM
  #69
codeflux's Avatar
figured it out. dropped the glovebox and was able to pull the upper glovebox light socket out from the inside, and replaced the last bulb. thank you for this write-up!
Old Nov 14, 2008 | 10:14 PM
  #70
Dranom's Avatar
glad you figured it out and your welcome!
Old Nov 17, 2008 | 07:11 PM
  #71
kala1's Avatar
ok iv tried not to bug anyone about this but how in the hell do u get to the parking light bulb inside the headlight housing .....or do i hv to take it in to infiniti ????????????
Old Nov 17, 2008 | 07:15 PM
  #72
codeflux's Avatar
turn your steering wheel all the way to the side opposite the one you're working on (to change left headlight turn the wheel all the way to the right), jack the car up, pull the wheel well lining (carefully!) - the part that's closer to the front of the car, obviously. reach in, you'll be able to feel the back of the parking light housing. turn it 45% CW or CCW (i don't remember which) to unlock it, pull it out, replace the bulb, reverse the process.
Old Nov 17, 2008 | 07:24 PM
  #73
kala1's Avatar
Thanks codeflux ...for a min i thought iwould hv to take out the wheel + fender wall ....that would suck big time
Old Nov 17, 2008 | 07:25 PM
  #74
codeflux's Avatar
no no, you can make do without that. i've done it a few times already, and can do one side in about 10 minutes.
Old Nov 17, 2008 | 07:48 PM
  #75
kala1's Avatar
Ok ill Give it a try this week end if my leds ever show up
