2006 Sedan Fog Light Kit??
Old Nov 20, 2008 | 12:29 PM
MALIBLOC's Avatar
Is there anyone out there thats has install PIAA or some other brand of fog lights along the bottom two vents?
Old Nov 20, 2008 | 12:34 PM
az1anbeethoven's Avatar
check out this guy, he did a real clean job with his...
https://g35driver.com/forums/g35-sed...-my-sedan.html
Old Nov 20, 2008 | 06:11 PM
Kazaam's Avatar
Yes I have. I have a sweet pair of PIAA 998 turbojector projectors. Here are a few pics, they are BRIGHT as hell!! By the way, I swapped bulbs out for an H3 HID kit lol
Old Nov 20, 2008 | 06:26 PM
1SlowSedan's Avatar
thank you!
Old Nov 20, 2008 | 06:29 PM
1SlowSedan's Avatar
Anyways, you have to custom fabricate it yourself.
I have a diy thread here somewhere or 6mt.net
Mine.
Old Nov 20, 2008 | 08:27 PM
Kazaam's Avatar
Originally Posted by 1SlowG35Sedan
wooooooohoooooO!!!!!
Aquafina FTMFW!!!!!! $4 for a case of 32 Courtesy of Sam's Club!!!!!!! Good choice for hydration after a long and hard install (no homo)DOMO
Old Nov 20, 2008 | 10:18 PM
gizmo134's Avatar
i put fogs in, but i hid them behind the grill.
Old Nov 20, 2008 | 10:22 PM
Kazaam's Avatar
^ That could turn out good if you go HID down there and brighten it up, regardless of color.
Old Nov 20, 2008 | 10:30 PM
gizmo134's Avatar
they are suprisingly bright, but the way i mounted them they dont quite point high enough, they basically cover between the front of the car to below the regular headlight beam.
i will admit, these are kinda cheap lights i bought at autozone, there little baby projectors, but they arent too bad. gonna go hid, just deciding on a color.
if you have any questions on doing it behind let me know. Took about 3 hours to install
Old Nov 20, 2008 | 10:32 PM
TurTLe*'s Avatar
did you pull the whole bumper or just removed the inserts...
Old Nov 20, 2008 | 10:48 PM
gizmo134's Avatar
^ pulled the inserts. got some self tapping screws, went into the bumper support. ran the wire up, and put a relay in the brake fluid area thingy.
Old Nov 20, 2008 | 11:00 PM
TurTLe*'s Avatar
nice, kinda gives me something to do, i have a set of OEM lexus ES300 fogs projectors, you just ran a normal relay and toggle switch with +/- independently?
Old Nov 20, 2008 | 11:09 PM
gizmo134's Avatar
i grounded each light at the fixture, and ran a pos. to the brake thing. mounted a relay in there, ran a fused line accross directly from the battery, then a wire into the car.
you could just toggle that, but i actually have 2 switches, one to turn them on and off, and another to have them go on and off with the ignition. "daytime running lights" haha
for switches, i wanted to be alil different. im deciding what to use to finish around this, but this is what i have.
when not being used, it flips up into the celing
Old Jan 7, 2009 | 10:16 PM
Stephan87's Avatar
hey man whats up sick car, i have an 04 coupe and want to put fog lights on mine. what do you think i should get and how hard were yours to put in. his is what mine currently looks like.
Jusseth
Sep 13, 2020 12:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
mjfenix
Jul 24, 2015 05:16 PM
attarday
Jul 15, 2015 04:03 PM
