G35 Sedan Light Replacement Guide
Old Jun 28, 2009 | 08:27 PM
Texasscout's Avatar
I'm waiting for the new LED headlights. I saw an ad for a sealed beam repalcement used on big trucks. I wonder if they can make a replacement bulb that will work in a conventional headlight like ours.
Here's a pic of the truck lites:
Old Dec 24, 2009 | 12:46 AM
screw&nut's Avatar
I'm new here but I have a question: I have an 06 sedan with reflector style headlights. It was my understanding that in 2006, the reflectors were replaced with projector style headlights. Is this true? Also, I need to confirm what type of xenon bulb I need. Is it D2S or D2R?
Thanks
Old Dec 26, 2009 | 06:14 AM
Blue Dream's Avatar
I drove ttrank's car solo
D2R and the only projectors in 06 came on the coupe, not sedan.
Old Dec 29, 2009 | 04:32 AM
lexusk8's Avatar
Just to add on to Blue Dream's post, the projector style headlamps on the sedan began with the 2007 model.
Old Dec 29, 2009 | 07:42 AM
Marinelli Motorsports's Avatar
Good info for everyone to know because the fitment guide on Sylvania site that most look to says D2S for 06 sedan.
Old May 2, 2011 | 02:02 PM
ACFD835's Avatar
So if i am reading this correctly, and the the fog/high is the same bulb then putting a bixenon projector in should be fairly straight forward...yes?
Old Oct 21, 2013 | 01:12 AM
AJY's Avatar
AJY
Originally Posted by machavez702
http://www.modifiedlife.com/2005-inf...lb-size-chart/
2005 Infiniti G35 Sedan Car Lightbulb Size Chart
Low Beam Headlight Bulb Size: HID-D2R
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 168
Front Turn Signal Light Bulb Size: 7440
Rear Turn Signal Light Bulb Size: 7440
Tail Light Bulb Size: LED
Stop Light Bulb Size: LED
High Mount Stop Light Bulb Size: LED
Fog/Driving Light Bulb Size: 9003/HB2
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 194
Map Light Bulb Size: DE3175
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
Trunk/Cargo Area Light Bulb Size: 158
Just made my life so much easier thanks.
Hasanbaloch
Feb 29, 2024 08:45 PM
Jusseth
Sep 13, 2020 12:25 PM
ClwMike
Jul 23, 2015 12:55 PM
Thunderaan
Jul 22, 2015 07:40 PM
igking
Jul 19, 2015 01:12 AM
