Hella Micro DE fog lamp HELP!
Old Jan 14, 2009 | 09:33 PM
baseball23's Avatar
Just got these fog lamps and im having trouble installing them. I want to install then behind the bottom two air ducts. Does anyone have a good DIY thead link for me or some help on how to do this. got a quote of 200 bucks for a shop to install it....that cost more than the lights, SO I NEED SOME HELP.
Thanks, Eric
Old Jan 15, 2009 | 01:12 AM
Sponger's Avatar
6MT Brembo Coupe
There's a couple of ways to mount. One is to remove the front bumper and mount to the aluminum bumper brace using spacers so the fogs will drop low enough to fit through the opening. The other is to remove the center grille and mount the fogs to the rigid vertical plastic braces behind the lower grille openings. I did the latter...I had just enough room to get back there.
$200 is a rip-off. If you were local, I would mount and do the wiring for a 12 pack
Old Jan 15, 2009 | 02:01 AM
baseball23's Avatar
ok i understand that, but i think i will still need a more in depth overview on exacly where to wire everything and how to remove the lower aire vent and mounting procedures and such...thats what im not to good with. Have you ever seen a DIY on here involving this?
Damn i wish you were local, id buy u a few 24pk cases not just a 12 pack!
Old Jan 15, 2009 | 10:09 AM
Sponger's Avatar
6MT Brembo Coupe
No, haven't seen a DIY. Should have done one since I've done this quite a few times.
I'll post additional instructions when I get home tonight.
Old Jan 15, 2009 | 09:50 PM
Sponger's Avatar
6MT Brembo Coupe
As promised...
-Mount fogs as described in my earlier post.
-Ground the negative sides of each fog. Make sure you ground it properly.
-Pull relay out of the Hella box. Look at numbers at underside of relay.
-85 goes to ground
-30 goes to the + terminal of battery. Make sure you use the inline fuse supplied with the kit.
-87 goes to both + sides of the fogs.
-86 will vary depending on how you want to trigger the fogs. I used the parking lights to trigger. The key is using a positive trigger.
-As for the switch, it will be wired in series with one of the wires coming from 86 or 30.
-Check all connections and tidy everything up using wire ties.
-Enjoy.
Old Jan 28, 2009 | 07:16 PM
Jamaica2G's Avatar
Did you get the kit with the HIDs or halogens?
Old Feb 25, 2009 | 06:45 PM
kala1's Avatar
dose anyone have pics on how to take the bumper off
Old Feb 26, 2009 | 12:37 PM
visibiliti's Avatar
^ there is a diy for front bumper removal somewhere, but the cliffnotes are:
10mm socket
Long flathead screwdriver
-take grill off
-turn wheels and take off front side of splashguards
-unbolt front bumper from plastic undertray
-unscrew some screws behind splashguards
-take out some plastic clips on top and bottom
-pull off bumper
Danielek
Aug 18, 2025 01:33 AM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
Freddy07g35
Sep 17, 2015 08:53 PM
twentyeggs
Sep 11, 2015 03:58 PM
Tylerttn
Jul 16, 2015 10:33 AM
