Drl help!!!
idk if this has been answered before, but i just installed and aftermarket LED strip in my head lights, and tapped them in to my DRL....but the Amber is killing my flow....so on a 04 coupe...is there a fuse or any EASY way to disconnect the amder DRL but still have it functional as a Turn Signal...im also new to G35, so id appreciate if you could PM my your responses so its easier to get to....Thanks i Really appreciate any help here...
ok...but idk if thats goin to fix the problem...i kno there are 4 wires that go into my amber drl...im sure one input is for the constant running, and the second is for the blinker input power.....i just dont kno which is which....
if you buy a bulb w/ one input (signal) then constant lighting will be eliminated. correct?
really? just changing the bulb shud do it?...imma go try that now...thanks for all ya'lls input...ill let u kno how it goes...
well...i tried the 7440 but it wud not insert properly with the blass ends...so i just detachedthe endingthat go to the DRL fillment off the old bulbs...and it worked perfectly...but luckly i do have a 2nd set of the bulbs if i ever decide to switch back(not likely tho...ill bost pics tonightto show u how it looks compared to the pic above....BTW i Do have a second set of HeadLIGHTS of a 04 coupe if anyone is interested....PM ME...They are in good condition...no bulbs or HID ballast...
klossfam
V36 Interior, Exterior & Lighting
33
Oct 31, 2016 12:11 PM
JerryG35x
Lighting
Feb 27, 2010 03:06 PM
zeadlots
May 22, 2009 08:22 PM
