reverse lights only work in neutral
Old Mar 14, 2012 | 12:24 AM
DouG35's Avatar
so my reverse lights only work in neutral 1-6 there off and evening reverse there off but when i go into neutral they come one i am lost someone please help me out can't find anything online at all
Old Mar 14, 2012 | 09:13 PM
UCIMAplaya2's Avatar
I believe these cars have a neutral switch though I don't know what it is used for. Maybe its possible to accidentally swap it with the reverse switch? Had any work done on the car lately? Or maybe your reverse switch needs an adjustment? Sorry I can't be of more help. Never heard of this
Old Mar 14, 2012 | 10:59 PM
056speedcoupe's Avatar
Look in the service manuals posted on the site if no one speaks up. My guess would be a reverse position switch on the transmission linkage is misadjusted. Should be a fairly easy fix. That's IF its on the linkage. sure someone here knows or can look it up. I'd look but I'm on my phone. First thing I would do is either read the manual or if you know how pull your shifter boot and trim away and look down in there to see if you see a switch of some type. The things with wires going to it. If you see one or two put the car in neutral(cause that's when your lights currently turn on. The switch you see being activated is the one that's turning the lights on. Now put the car in reverse and adjust it so it makes contact when in this position. BEFORE STARTING THE CAR move the shifter back through all the gears and make sure the lights now are working as they should. This will insure you adjusted the right switch if there is a nutral position switch as well. Hope that helps.
056
Good luck
056
Old Mar 15, 2012 | 02:11 PM
DouG35's Avatar
Got it taken care of thank you guys
Old Mar 17, 2012 | 12:29 PM
so for future reference, what was it?
Old Mar 13, 2021 | 11:51 AM
G35Quise's Avatar
G35 Coupe Brembo package 6MT
what did you have to do to fix this issue? My car is doing the same thing
Old Mar 13, 2021 | 12:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Your note says you have a 6MT but you're saying your reverse lights only turn on in neutral?
Old Mar 13, 2021 | 12:36 PM
G35Quise's Avatar
yea I have a 04 6MT Brembo Package, only in neutral they come on, and not in reverse
Old Mar 13, 2021 | 12:50 PM
cleric670's Avatar
BANNED!!!
Sounds like your backup lamp switch on the left side of the transmission is screwed up.
Unfortunately it's also a PITA to get that one removed with the factory "weight plate/dampener" thing in the way. Hopefully yours has already been removed or has rusted off.
ya_boy_ant
Oct 3, 2014 09:35 AM
barrios35
Aug 15, 2006 11:23 AM
JSuppi
Aug 13, 2006 12:54 PM
SDG35cOwner
Oct 15, 2004 10:58 AM
