Headlights HELP PLEASE
Old May 12, 2014 | 06:37 PM
BrooklynCoupe's Avatar
***DISCLAIMER***
I am a noob /:
So recently, I purchased a salvaged 2006 g35 coupe.
Took it to the mechanic and noticed the headlights weren't working.
So after investigating it, he said that the "wire harness" was stolen (He has a heavy accent,couldn't understand him so not sure what he said) He only showed me the part which looked like a adapter or something but he said when I buy all three bulbs(low/hi & fog), to make sure they include the wires connected to them.
Being the cheap person I am, I went on eBay to look for these headlights harnesses and can't find anything. I don't even know what bulbs to get nor which specific bulb.
Am I looking for the correct item or is there another specific term for them?
How much do the set cost including harness and bulbs?
Are there any vendors online that sell these parts?
I think they're factory HID but not sure.
I need it for both headlights.
Also, in overall, the headlights need to be replaced but I don't have the money for them.
Can anyone help? I'll upload the pictures of the headlights so you guys can get a idea.
Attached Thumbnails Headlights HELP PLEASE-20140508_160435.jpg   Headlights HELP PLEASE-20140430_180752.jpg   Headlights HELP PLEASE-20140424_130716.jpg   Headlights HELP PLEASE-20140430_180806.jpg
Old May 12, 2014 | 06:53 PM
Lartytiejdke3's Avatar
i doubt the headlights need to be replaced. they look fine.
wiring harness and bulbs are two different things. i have a hard time believing someone stole your wiring harness???? are you missing ballasts??
what exactly is not working with the headlights. which ares specifically.
also you gotta find a different guy to work on your car...
Old May 12, 2014 | 06:57 PM
ScraggleRock's Avatar
I'll bet money its the ballasts. The bulbs don't really go, so that would be the last thing I would replace. You can find the ballasts used on eBay for like $60.
1: are both in non working condition?
2: are you going to the third position on your light switch to check them? Cuz the first position has a light sensor. If you're trying to turn them on and its light out they won't come on in the first position.
Old May 12, 2014 | 07:02 PM
and good God, is that a crater on the outside of your driver seat???
Old May 12, 2014 | 07:12 PM
Urbanengineer's Avatar
Look at the last front pic it's cratered in the door.
Old May 12, 2014 | 07:23 PM
I've got the door fixed already.
1. The left headlight's fog light is the only working bulb out of the set.
2. The used dealership I've bought it out seemed a bit sketchy, hence why I thought they stole it off the car since they stole the ashtrays that were in the car before it was delivered
Old May 12, 2014 | 07:25 PM
youre gonna have to see if you have ballasts or not. from there you can see if indeed wiring harnesses are there as well. and likewise, if theres any bulbs. while theyre off, buff the headlights out to remove that oxidation, finish it with a uv protectant clear coat of some sort to protect from future hazing and you should be set headlight wise.
The headlights were wobbly at first, my mechanic told me that a piece inside broke as the result of the collision.
Old May 12, 2014 | 07:27 PM
that sounds like a broken plastic tab
Old May 12, 2014 | 07:32 PM
I'll check tomorrow to see if I have ballasts or not. I will take photos and will update this thread. Thanks for the help so far.
Old May 31, 2014 | 09:16 PM
madmang0's Avatar
If i wanted to just swap out my ballasts in my 04 coupe for new ones, do i still have to remove the front bumper?
Old May 31, 2014 | 10:27 PM
ILCruisin2006's Avatar
You really had to ask thread jack three different threads with the exact same question?
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
