Question about my H1 fog lights.
Have a question about my H1 bulb fog lights (the lower portion bulb on our multi bulbed headlight lol). My lights seem to point more upwards than downwards towards the road like u see here in the pic. You should see lighting on the ground correct? If I flip the bulbs would it fix that problem or how do I get them to reflect more towards the road than upwards. They do shine on the road, just not as much as fog lights are supposed to... hence they are fog lights so you can see the road better thru fog/rain and crappy weather.
Yep ^ you can adjust the vertical (no horizontal) position on the H1s using the procedure found in the FSM.
http://psedog.com/cars/fsm/g35/
Ya I got them down towards the road more though I didn't need a Philips I needed a 8 mm wrench on the little screw and turned them both counterclock wise. Now I need to get my D2R ballasts fixed lol
g35man04
Sep 24, 2007 04:07 PM
