Fog Light Replacement - HID look?
Old Sep 1, 2005 | 12:49 AM
  #31
Triple8Sol's Avatar
Originally Posted by PeteNJ
You need to find a vendor who sells Osram Silverstars NOT Sylvania Silverstars. They are the same company but the Osram bulbs are European spec and DO NOT come with a blue coating. I cannot remember off the top of my head what vendor I got it from. Try a search.
Here is a blurb about the Osram Silverstar line:
http://www.osram.com/cgi-bin/press/archiv.pl?id=161
Pete, I totally agree with you. The Euro-spec Silverstars are 30% brighter than stock, while the US-Spec Silverstars are 10% brighter. PIAA Superwhite bulbs are something like 10% LESS bright than stock.
Old Sep 1, 2005 | 10:13 AM
  #32
erikill's Avatar
Really that much? Hmm I think I may be sold on those osrams. I tried to research the lumen output on other bulbs, but only osram / slyvania had the ***** to list the actual output and not that "equivalence" to 125 / 135 W. I'd just like to see how close the color is to the HID, but if its 90% there good enough for me to gain some extra light. Also I may put them in my old volvo (uses 9003 / H4) if they can be brighter.
Old Sep 1, 2005 | 10:13 PM
  #33
BombRush's Avatar
H4 OSRAM SILVERSTAR +50% XENON CAPS, 9003 GERMAN
Will these right bulbs for G ?
Old Sep 1, 2005 | 10:18 PM
  #34
tony's Avatar
Originally Posted by skeleton_cru
Don't confuse color temp. with light output/brightness. The 6k HID bulbs are NOT brighter than our stock HID bulbs, they are only a different hue. My advice would be to stick with the stock HID's and replace the fogs with an H4 bulb with a color temp between 4500 and 5000 k.
I had the MTEC's and the highbeams were useless.. didnt illuminate for shyt at night
Old Sep 2, 2005 | 12:09 AM
  #35
erikill's Avatar
bombrush yes, don't outbid me :-P there are 2 auctions haha. I think they may be closer to 3800K less yellow, but brighter so I guess upgraded fogs can help.
Tony any other brands you've tried? PIAA xtreme white would match almost perfectly but less light than the stock fogs.
Old Sep 2, 2005 | 05:25 AM
  #36
skeleton_cru's Avatar
Sedan
I had the Sylvania SilverStars and the PIAA Xtreme Whites. The SilverStars did not match the HID's as well as the PIAA's, but they seemed brighter (especially the high beams). The PIAA's match the HID's very nicely, but they are not perfect. I now have PIAA Xtreme Force. They are rated at 4700k, but they look exactly like the Xtreme Whites to me.
Old Sep 2, 2005 | 07:40 AM
  #37
erikill's Avatar
well if I want more visible light output (lumens) I should go w/ the Silverstars? The PIAA I've read is less than stock light output, what were your thoughts since you had both?
Old Sep 2, 2005 | 02:48 PM
  #38
Sedan
You have to remember that the fog/highs are auxiliary lighting. The HID’s are what’s doing most of the work. The only difference in brightness I noticed between the SilverStars and the PIAA’s was the high beams. Also, I had Sylvanias, not Osram. Maybe you’ll notice a difference with the brighter Osrams.
Old Sep 2, 2005 | 06:33 PM
  #39
erikill's Avatar
Right, well with slight tinting and rain storms here frequently in GA I'd like the most light possible but match the HID's rather close. If the OSRAM's are 80% there but 30-50% brighter than stock that is a good trade off. If it is the same as stock, I'd rather just lose the 10% and go with the PIAA's. Too bad we didn't get projectors, I dunno if I would drop the 1k or so to get retro-HID's.
Old Sep 2, 2005 | 08:53 PM
  #40
Sedan
When changing my fog/highs, color matching the HID's was my first priority although I agree light output is an important consideration. Coming from a Ford with halogen headlights, the HID's were like sunlight for me.
Old Sep 3, 2005 | 12:26 AM
  #41
erikill's Avatar
hey if its not so obvious as the yellow halogen vs HID then its all good. I wish I could get color temps & lumens for all the lights, only OSRAM has the lumen output. Suprised PIAA doesn't tell me.
Old Sep 3, 2005 | 01:13 AM
  #42
Sedan
I'm not. They probably don't list the lumens because they're not worth advertising. Even so, I have had good experiences with PIAA so I can't complain.
Old Sep 3, 2005 | 01:25 AM
  #43
erikill's Avatar
I agree the bulbs rock, but again 80% close brighter or 100% close and -10 % brightness.
Old Sep 3, 2005 | 02:31 AM
  #44
BombRush's Avatar
OSrams definately give white look right??Not like stock Fog lights
Old Sep 3, 2005 | 06:53 PM
  #45
erikill's Avatar
not sure.
btw bombrush, where did u get ur clear corners from?
