194 leds keep blowing out then strobing ahhhhhhhhhhhhh
Old Dec 20, 2005 | 01:14 AM
ebuy929's Avatar
hey guys,
i have led 194 bulbs in my headlights and corners but they go out every month ive spent hundred of dollars on them using all diffrent name brands
thay keep going out and changing them is so annoying
first they start blincking then they stop working
anyone know of any good 194 led bulbs i can get that wont burn out as much even piaas go out
my corner leds last a while but in my hjeadlight clearence strip they burn out so often
Old Dec 20, 2005 | 01:28 AM
Rever's Avatar
Sounds like you're pushing too much current across the LED. Before trying different bulbs I would take a volt meter to your inputs. I've had LED's in my corners for over a year with 0 problems....never got around to doing my headlights. For some reason I think your G is putting out a bit more juice.
If the juice is right than PIAA is more than likely running they're LED over they're rating (typically 30mA for "false" white).
....Has anyone else had this problem?
Old Dec 20, 2005 | 12:21 PM
ebuy929's Avatar
i dno but its happend to my friends sedan as well as my other friends coupe so i think its the brand
any advice guys
Old Dec 20, 2005 | 12:40 PM
ivory05coupe's Avatar
recently i've been having the same problem, but only on the passenger side. I've recently went through 2 sets of LED's just for the one side. Now I just switched it back to the stock bulbs and we'll see if I still have problems
Old Dec 20, 2005 | 04:56 PM
pp7's Avatar
pp7
Could it be because of the heat from the headlights?
Old Dec 20, 2005 | 07:02 PM
ebuy929's Avatar
i doubt it they just seem to have a short lifespan i found better piaas bulbs called tera but there 80 buz a set rather then the 20 dollars i use to pay
i dno if its worth inversting in new bulbs will it chjange the life span
Old Dec 20, 2005 | 08:34 PM
G35Lin's Avatar
Multi-Spoked Mod
PIAAs usually don't burn out.. i had them for like 1.5 years and it was fine..
Ed lin
Old Dec 20, 2005 | 10:06 PM
ebuy929's Avatar
what kind of piaas and where they inthe headlights?
Old Dec 20, 2005 | 10:24 PM
escobar929's Avatar
i've had my PIAA teras for like 6 months and no problems
Old Dec 20, 2005 | 10:31 PM
ebuy929's Avatar
esco 929s a nice number lol ummmm you have piaa teras in the headlights? are they a nice color , how long do they typicly last and how much where they
Old Dec 21, 2005 | 04:08 AM
escobar929's Avatar
ebuy929, lol. i got tera's in the clearence strip and in the corners. i really like the color, they are the only bulbs that completely fill the whole strip. i payed like $50 for a set of two bulbs. for that price they better last forever
Old Dec 21, 2005 | 04:10 AM
escobar929's Avatar
BTW do the stock bulbs also burn out or is it just aftermarket ones?
Old Dec 22, 2005 | 07:40 PM
ebuy929's Avatar
no just the aftermarket ones
ya i guess ill order the piaa tera like you have hopefully theyll last
g.spot
May 9, 2016 10:54 PM
Gabe83714
Oct 6, 2015 06:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
