Will the G35 manual tranny fit in the M35?
Short answer not worth it too much work.
and like i stated earlier the crankshafts are different. With that said its not impossible but would require a lot swapping over parts to accomplish that.
The-Dream (09-13-2022)
Received 2,469 Likes
on
Coupe 6MT Premium RAS
Crankshafts are the same, 5AT comes with a centering plug and the 6MT comes with a pilot bushing. You can remove the plug and put in the pilot bushing.
The CD00X transmission mates to all the VQ35DE RWD configurations, you can use the block from a Z, G, M, or FX. Doesn't matter if it was a rev-up or a non-rev DE engine, the bellhousing is the same, the 6MT will bolt to it.
The bigger issue will be getting the correct ECM, I'm pretty sure you would be able to use one from a 6MT G sedan though. Or just have it UpRev tuned which I think would allow you to use the factory one.
Your short answer is pretty correct though, too much work and not worth it![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
laksjd84
07-24-2015 05:12 PM
