Help! Rear creaking noise from my infiniti g35 2004
Old Jul 24, 2015 | 04:00 AM
rezendvous420's Avatar
Hello everyone,
So I am here with some questions for my Infiniti G35 RWD 2004, Recently I have noticed my car has been making creaking noise from the rear, I have just replaced my rear lower control arm on both the sides, rear shock absorbers on both the side, front passenger side upper control arm, front wheel bearing and did an alignment. The car was in accident I was trying to do a bit of drifting then hit the curb by the footpath.After everything was replaced it did run smoothly for a bit then every time I drove over bumps or uneven pavement in slower speed I can hear the car making creaking noise from the rear suspension, I did a lot of research on forums from Google and found out the sway bar bushing could be an issue. I took it to my mechanic pulled my bushing out greased them up and put them back in, It did nothing. I took it to Nissan they figured it could be the lower control arm bushing that is making the noise and they were replaced just couple weeks ago so I asked my mechanic who worked on my car to grease them up with graphite and still the noise seem to be there. the only other thing I could think is the end links connecting the sway bar. they seem fine to my mechanic. I am not sure what is going on? Is anyone else having the same issue who has a solution to this?
Could it be bad sway bar end links?
I was thinking rear wheel bearing but noise coming out from the rear suspension making me confuse.
Any help or suggestions please?
Thank you in advance.
Old Jul 15, 2016 | 03:26 PM
rynoinaz's Avatar
i had same noise, would creak when rolling over speed bumps or really any uneven surface......it was my sway bar end links
Old Jul 16, 2016 | 10:55 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
End links and D bushings can make squeaking noises.
Old Oct 3, 2019 | 02:15 PM
David Gray's Avatar
G35 Sedan
Hey guys should I remove this broken piece of camshaft sprocket.or leave in? Need hel
Hey everyone i need help! Should i remove this broken piece or leave in? There is a spring and something else i dont know if it regulates oil into sensor?? It rattles a bit
Old Oct 3, 2019 | 03:27 PM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
Why did you post this on an unrelated thread from 3 years ago?
Should you remove it? The entire VVT actuator is broken and needs replaced. Move it, don't remove it, it probably doesn't matter at this point.
https://g35driver.com/forums/g35-sed...ing-works.html
Old Oct 4, 2019 | 02:34 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Technically those cam sprockets are non-serviceable. Yours definitely needs to be replaced and unfortunately it's not cheap.
Old Oct 19, 2019 | 11:52 PM
G35namedfranny's Avatar
G35 Sedan, high compression,Poncams,exhaust,porting to heads and intake,lowered on coilovers,tuned
Had same problem.
I had the same problem but worse when i built my engine. Mine actually broke worse and got jammed up. What i did was redo the entire timing set,bought a set of low mileage JDM sprokets from someone on ebay that imports engines and parts. I would highly recommend not running it like that. I also would advise OEM only and not some aftermarket "junk".
Old Oct 21, 2019 | 09:41 AM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Originally Posted by rezendvous420
Hello everyone,
If you've been working with the rear control arms and have had any replaced here is something to try. The control arms move up and down by virtue of the bushing twisting slightly as the arms move. When it was off the ground being replaced if the arms were hanging downward with the suspension fully extended when the bushing to frame bolt was torqued down it will overstretch the bushing when the weight is put back on it. I've had this happen in the past when I got in a hurry to get done. Jack the rear of the car back up and put jackstands under the outer ends of the control arms. If you have a friend with an oil change pit it's even better. Loosen the bolts attaching the control arm bushings to the frame and "bounce" the rear of the car up and down a few times to center the bushings then re-torque. Hope this helps.
Old May 26, 2020 | 12:03 PM
DETLAW's Avatar
Infiniti G35S
'07 G35S - Rotted Out Rear Subframe
My 2007 G35S (6MT) - the love of my life - has been squeaking and creaking lately. Brought it to my mechanic who discovered that the rear subframe has rotted out and cracked. The part alone is $1,900. To replace it, with all the tie rods and such, we are talking $3K. My car only has 138,000 miles on it. However, there is a noise that I keep hearing in the transmission (at first, backing up alone when the engine was cold. Now, it's heard even going forward) that makes me think I have a trani issue brewing. Thus, I've made the tough choice to not repair, but replace the car. What makes it really tough on me is that I've never driven an AT - the G35S is the 5th car I've owned, and all have been MT.
Such a sad day
Old May 31, 2020 | 01:24 PM
cleric670's Avatar
BANNED!!!
The subframe is VERY unlikely to be rusted out, what piece exactly is he talking about. I suspect it's this subframe brace which is a common part to rust apart.
https://www.z1motorsports.com/front-...er-p-6012.html
If you don't know what piece exactly is rusted then take some pictures of exactly the part and post it. I think you're getting robbed if someone is trying to charge you $1900 for a subframe...
Old May 31, 2020 | 01:26 PM
cleric670's Avatar
BANNED!!!
Just for reference, you can buy a used engine cradle, subframe brace, or rear subframe for under $200...
dr_dangus
V36 Brakes, Suspension, Wheels & Tires
Sep 4, 2019 11:50 AM
Ichiglo_
Sep 24, 2018 04:45 PM
PSG35
May 29, 2014 07:41 AM
kennymo
Jun 30, 2012 02:05 PM
B FIFE22
Mar 4, 2011 02:07 PM
