airbag llight
Old Feb 22, 2008 | 01:36 AM
jdmv35_99's Avatar
airbag llight
my airbag light is blinking and it doesnt stop..what could be the reason??
Old Feb 22, 2008 | 11:34 AM
Big Rob's Avatar
Never gone
Why is this in the Check Out My Wheels section?
I'm sure a Moderator will move this to the proper area, where the OP can get some helpful responses.
Old Feb 24, 2008 | 11:50 PM
06g35meister's Avatar
ttt, mine started blinking after i took my seat out to vacuum hardcore... will resetting the ECU work?
Old Feb 26, 2008 | 11:52 PM
xjonmo's Avatar
mine started blinking for no reason at all
Old Mar 3, 2008 | 06:09 PM
JDM_SKY's Avatar
same here. just happened today.. anyone knows the answer??
Old Mar 3, 2008 | 06:10 PM
make sure the seats are plugged in all the way, but i think we will be forced to have the dealer reset it...
Old Mar 3, 2008 | 06:11 PM
for nissans:
How to reset SRS(air bag) light:
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired.
Old Mar 3, 2008 | 06:50 PM
had one person report it didnt work, can i get a second for verification??? this one person could actually have a problem, but i want to make sure before i send him to the stealerships.
Old Mar 3, 2008 | 06:57 PM
zackt69's Avatar
rarejdm.com
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset.
^^ thank you, you rock.
Old Mar 3, 2008 | 07:00 PM
zackt69's Avatar
rarejdm.com
I went through this a few times with the after market steering wheel I had for a while, and the first time I disconnected my clock of all things. If the light comes back on, then something is wrong and the car should be taken in... this simply resets and clears the light.
Old Mar 3, 2008 | 07:02 PM
rookie's Avatar
Here's the diagnostic mode from the service manual. It's out of the 05, but I looked in the 03 and it said the same sequence.
Warning lamp examples.
This has worked for me in the past when something was left disconnected.
Old Mar 3, 2008 | 07:05 PM
once again, a sucessful fix by the know it all's,. thanks guys!!!
Old Mar 3, 2008 | 07:11 PM
jdmv35_99's Avatar
yes i tried it right now and the light went off..thanks guys....
Old Mar 3, 2008 | 07:13 PM
zackt69's Avatar
rarejdm.com
sweet
