WORK Teaser
Old Dec 2, 2008 | 09:03 PM
  #61
CandlestickPark's Avatar
ill Sedan
^Go with the Aero Kit I don't believe its much lower than stock, if at all, I'm pretty sure I remember G35Papa posting this recently (those that have it can chime in).
Old Dec 2, 2008 | 09:10 PM
  #62
SouthernG35's Avatar
Candelstick is right the Aero kit does not sit much lower than stock. I did not measure before I isnstalled mine but I would guess maybe a 1/2" lower than stock in the front.
Also would love to see some better side profile pics. I think from the pics you have up now a 5mm spacer on all four corners would really make them more flush.
Old Dec 2, 2008 | 09:41 PM
  #63
NAT@FFTec's Avatar
looks great! looks like you can go a little more aggressive in the rear though
Old Dec 3, 2008 | 12:27 AM
  #64
NorthSideRacing's Avatar
looks good.
Old Dec 3, 2008 | 12:33 AM
  #65
G35Papa's Avatar
Sweet, it worked out...glad to see that
CandlestickPark is correct so hurry up and get the kit or get the Kurookie front one, it will also sit at equal height with the OEM sides or Aero sides.
Old Dec 3, 2008 | 12:56 AM
  #66
ill Sedan
+1, can't go wrong with the Kurookie bumper either, less than the full Aero kit and looks so sick.
Old Dec 3, 2008 | 01:07 AM
  #67
FutureGDriver's Avatar
Nice... Fit perfect i bet that was a relief for u...
Old Dec 3, 2008 | 01:50 AM
  #68
O HELLA JDM's Avatar
sweeeeeeet
Old Dec 3, 2008 | 01:51 AM
  #69
heyitsalex's Avatar
can go an easy 20mm in the rears and 5mm more in the fronts. Also, isnt the rear tire put on backwrds?
Old Dec 3, 2008 | 11:44 AM
  #70
bowzer's Avatar
Some cold, frost-covered, early morning day-time pics. I will do some more tweaking in the coming days/weeks with the wheels. Try out some more spacers front and rear, better quality hub rings, and some different matching blue lug nuts. Then the wheels will go away for the cold winter.
Old Dec 3, 2008 | 12:02 PM
  #71
gtrefever's Avatar
it'd look way better if there wasnt a wheel gap, but it still looks good.
Old Dec 3, 2008 | 12:10 PM
  #72
bowzer's Avatar
Same here, but the wheels/tires I had on before had less than a finger gap, these have more due to the mild stretch of the tire. I could move to a coil-over setup for the adjustability, but it's already low enough on my 350z h&r springs. I hope to solve the gap with small spacers. It's all a learning game right now as no-one else really has this setup, so it's a bit of trial and error.
Old Dec 3, 2008 | 12:22 PM
  #73
O HELLA OEM's Avatar
i love that concaveness!!
Old Dec 3, 2008 | 04:19 PM
  #74
AARONHL's Avatar
The blue G needs some Mother's Back To Black on the lower plastics!
Old Dec 3, 2008 | 04:24 PM
  #75
Tunerz_Store's Avatar
are you running a square tire setup? Hell looks like you have room for a bigger tire in the back easily, a spacer would help too.
