WORK Teaser
Old Dec 3, 2008 | 07:06 PM
  #76
NorthSideRacing's Avatar
turned out nice
Old Dec 3, 2008 | 07:10 PM
  #77
bowzer's Avatar
Originally Posted by Hybrid_DET
are you running a square tire setup? Hell looks like you have room for a bigger tire in the back easily, a spacer would help too.
By square do you mean non-staggered? If so, I'm running 245/40/18 all around. I too, was actually surprised by the amount of room in both the front and back. I think there was more of a stretch than anticipated. I will eventually go with a wide tire out back, but I had these tires on my other rims and they still have 90%tread.
I think tomorrow if I have time I will put the 20mm spacer on the front and rear and see how much I can push them out further
Old Dec 3, 2008 | 08:01 PM
  #78
Mustang5L5's Avatar
Needs a wider tire. I think the stretched look is taking away from the potential.
The wheels look good though, just needs wider rubber. A 9.5" wide rim should really have a 285-295 width tire mounted on it.
Old Dec 3, 2008 | 09:43 PM
  #79
heyitzalex's Avatar
looks good, full face is the new steplip!
Old Dec 3, 2008 | 10:27 PM
  #80
entranzdG's Avatar
love the concave look been wanting to do that for awhile now.. awesome wheels and nice car!
Old Dec 3, 2008 | 11:50 PM
  #81
FlyingLumpia's Avatar
I think a 255/40/18 would look perfect on there.
Old Dec 3, 2008 | 11:55 PM
  #82
Gdup35sedan's Avatar
ENVautoDetailing.com
Looks good, but you have WAAAAAAAY more room than i thought you'd have! glad it worked out and you didnt have to send the wheels back.
I'd go with a 10mm spacer up front and a 20 in the rear, it'll look bitchin!!
-GP-
Old Dec 4, 2008 | 12:54 AM
  #83
-GP-
i was thinkin the samething. then lower it about anothe 1inch or 2... hehehehe
Old Dec 4, 2008 | 01:25 AM
  #84
gtrefever's Avatar
hahaha tryna get him to be flush
Old Dec 4, 2008 | 01:45 AM
  #85
ha, if only i could have experimented with more wheel setup's when i was slammed and actually liked my car! 8.5/9.5 +10 with 225/235 tires and -2.5 camber all around FTMFGDW!!!
-GP-
Old Dec 4, 2008 | 06:19 AM
  #86
BuckeyeG's Avatar
-GP-
When you actually likes your car?
Old Dec 4, 2008 | 07:06 AM
  #87
bowzer's Avatar
"A 9.5" wide rim should really have a 285-295 width tire mounted on it"
Not on our sedans, most who have a 9.5 out back run a 275 tire. That's an option when I need new tires, but I like having the ability to full rotate the tires.
"I think a 255/40/18 would look perfect on there."
That's what I said to my installer buddy when we mounted them. A 255 could work. Like i've said, once these tires wear down, i'll have to make another decision on sizing.
"I'd go with a 10mm spacer up front and a 20 in the rear, it'll look bitchin!!
-GP-"
I've got the 20mm spacers from my old wheels that i'm going to test fit this morning. I'll try them front and rear and make a final decision what to get.
"i was thinkin the samething. then lower it about anothe 1inch or 2... hehehehe"
I'd loove to slam it down, just couldn't justify the other sacrifices i'd have to make. The wife already complains about how low it is. I'm dropped aprox. 2" now with the 350z h&r springs.
Old Dec 4, 2008 | 07:58 AM
  #88
Mustang5L5's Avatar
Seems like a waste to run a wide rim with an undersized tire IMHO. Guess i need to change my way of thinking with these cars. My "other car" runs a 315 series tire on a 10" rim out back and 275's on a 9" rim up front.
Wheels look good btw
Old Dec 4, 2008 | 08:50 AM
  #89
bowzer's Avatar
^^^The problem is actually fitting all of that tire in the wheel wells, by your sn i assume you had/have a mustang, on that the wells allow a very wide tire, ours not so much. When these tires wear out, i'll most likely go to a 275/40 in the rear.
Here are test fit pics w/20mm spacer on the back, too much poke. I will prolly just stick with a 5 in the front and a 10 in the rear.
Old Dec 4, 2008 | 09:02 AM
  #90
Mustang5L5's Avatar
Had 2, traded 1 in for my G35x.
I'm just not a fan of the stretched look although it's not that bad and i don't blame you for wanting to keep perfectly good tires for now.
Could be worse
