The Process Begins....
Old Apr 14, 2009 | 10:43 AM
  #31
Heist.'s Avatar
Originally Posted by Wannabe6MT
What exactly are you doing? Repaint the car?
complete debadge / clean up of everything like moldings etc.
Then yes but I am painting it matte / satin black probably.
Old Apr 15, 2009 | 01:41 AM
  #32
Heist.'s Avatar
Suffered all day today again sanding my fingers away. I will update pictures tomorrow or thursday probably
Old Apr 15, 2009 | 01:49 AM
  #33
G35Papa's Avatar
You're an animal for taking on such a huge job....props man.
As for the door handles. They do remove from the inside, behind the door panels and then a metal sheet cover. If I remember correctly, there are 2 or 3 screws holding them in. My paint guy had to remove the windows to get to them easily. Not sure if you can avoid that or not.
Old Apr 15, 2009 | 01:52 AM
  #34
Heist.'s Avatar
yeah I always jump into **** like this, I regret it right now, but the finished product
Anyways yeah i figured it would be like the rest of this car and be impossible to get at.... I get to do all the plastic / trim thursday
Old Apr 15, 2009 | 02:02 AM
  #35
Heist.'s Avatar
forgot to add I light my trunk on fire. It was some shenanigans, welding + hurry = smoke and fire.... Now need all new fabric for the trunk
Old Apr 15, 2009 | 02:06 AM
  #36
akachi's Avatar
wow thats a lot of work
Old Apr 15, 2009 | 02:13 AM
  #37
Heist.'s Avatar
yeah I recommend against it for anyone that wants to have 2 weeks of there life not used for it and a ton of frustration! But its a great experience I am learning a ton daily.
Old Apr 16, 2009 | 07:48 PM
  #38
Heist.'s Avatar
18th bday
Old Apr 16, 2009 | 07:54 PM
  #39
az1anbeethoven's Avatar
damn, thats a gangload of work
Old Apr 16, 2009 | 09:38 PM
  #40
naughty240's Avatar
OP to get handles out.
Pull off door panels
Hook up window up and down switch
Roll down window till you see the bolt that holds it onto the arm. One bolt is accessed through a hole
Pull window out
remove the 10mm bolts that hold on big black panel
pull out black panel and remove wire harness
Then handle comes right out. Held in by 2 10mm
20 min job at the most
Old Apr 17, 2009 | 01:23 AM
  #41
Dranom's Avatar
wow! props! keep it up!
Old Apr 17, 2009 | 01:31 AM
  #42
Heist.'s Avatar
ahahahaha yeah more then I never thought
Pull window out
Yeah I figured it out today I will do it tomorrow probably.
Dranom - Thanks for the support man !
Old Apr 17, 2009 | 06:11 AM
  #43
PPGFREAK's Avatar
Are you going to take out the front and rear windshield? and your going to take the bumpers off the car to paint? and the weather stripping on both sides of the roof to? and the chrome mouldings? Its nice to see some one doing somthing them self, but theres a lot more to painting my friend Your going to have to sand behind all the places I listed, and I recomend you pick up a $10 box of latex gloves for sanding and preping so you dont take the oils from your hand and put them right on a freshly sander panel. What grit sand paper are you preping with? You said your fingers hurt in a post...... are you sanding the hole car with a DA or block, or your fingers?!
Old Apr 17, 2009 | 04:54 PM
  #44
STCLAIRWEST's Avatar
do you plan on painting the engine bay too?
Old Apr 17, 2009 | 05:02 PM
  #45
Heist.'s Avatar
No,yes,maybe,maybe. And no there isn't really much more to painting. Sand, prep, paint. Just how nice you want it to come out. Yeah using my 400grit nails to really get it ready. ..... No just a lot of little things I had to do that day which involved hand sanding like under the bottom moldings, door jams etc.
I do use gloves, just not in the pictures.
I used 320 to 600 on the parts that were in great shape.
The rest depended on how it was in some parts I had to drop all the way down to 80.
Thats been on my mind all day I am not sure how I want to do it. I am doing the hood but I don't know about the rest.
