The Process Begins....
Old May 3, 2010 | 01:27 PM
  #811
Matzo Ball's Avatar
those came out very well and the whole ride looks great. Spacer? If so, how large and a rookie front, right?
Old May 3, 2010 | 08:38 PM
  #812
Heist.'s Avatar
I feel like I put 20 or 25 in the front and 15 or 20 in the back I will have to look later, but thanks and also yes rookie front!
Old May 3, 2010 | 09:35 PM
  #813
NjMatteSedan's Avatar
No way u put spacers that big lol I put 10mm in the front and they're perfectly flush
Old May 3, 2010 | 09:54 PM
  #814
SxSkyLinexS's Avatar
update on ur car heist!!
i havent seen this thread in a while
Old May 3, 2010 | 11:35 PM
  #815
Heist.'s Avatar
haha 25mm front and 15mm rear . Not kidding.
running 215/35/19 General EX and rear is 235/35/19 General EX so its more around 225 annd 245
Old May 3, 2010 | 11:47 PM
  #816
^ u know the routine
  #817
CandlestickPark's Avatar
ill Sedan
I completely forgot you had done a projector retrofit. What projectors and shrouds did you use? Halos look sick, nice work man.
Old May 3, 2010 | 11:48 PM
  #818
^ exactly proves my point to post pics
Old May 3, 2010 | 11:55 PM
  #819
Heist.'s Avatar
all the pictures are on the previous page of the new wheel setup.
Also Marcus I used fx ones I think? Really not sure or just g35. They are the low and high beam in one. I will look for the receipt.
Currently I don't have a shroud. When i was cutting out the housing I broke it so I had to make the housing from scratch and just never got around to buying shrouds. It's a work in progress for the summer I'm going to go quad projector and mold in shrouds.
Old May 3, 2010 | 11:59 PM
  #820
ill Sedan
Very cool. I'm eventually going to do quads as well, but gotta figure out how to install the shrouds up top. You should swap out your lenses to clear ones when you open up your lights to mod them again. Cutoff will be much sharper and you'll get that cool color "flicker".
Old May 4, 2010 | 12:00 AM
  #821
MOARRRRR HEIST!
and what happened to ur front bumper?
did it get into a battle? or is that white paint
Old May 4, 2010 | 12:01 AM
  #822
Heist.'s Avatar
Yeah Marcus I totally forgot about those. I will def copp some when I get everything else in the summer. How do you plan on actually placing the projector in the housing?
Old May 4, 2010 | 12:04 AM
  #823
Heist.'s Avatar
SxSkyLinexS - A mixture of driving dumpt in the rain hitting stuff and a piece of tire hitting me on the freeway. Along with a ton of rocks off the freeway when I had to drive up to arcadia for work. My front bumper has been through a lot
Old May 4, 2010 | 12:05 AM
  #824
nevermind about a battle
its been a war!
haha
i would suggest you wrapping the clear bra material on the car to ur bumper or at least the bottom half?
i dont know how it'd look on that paint of urs though
im pretty sure u'd hate to repaint it every few months
  #825
ill Sedan
I dunno yet. Per IvoryGTs and Ttrank's suggestions I'm going to go with Lexus RX or S2K projectors because they are small enough to work with up top. I know I'll have to trim the shroud (and possibly parts of the projector) to get it to fit properly.
