OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 11, 2010 | 12:56 PM
  #1711
3crchino's Avatar
Ok so I've been tyring to find some wheels for my G, and I want to get something with a Low offset like 0 or 10. Only problem that I am having and I don't know if it is b/c I am not looking in the right place or it is a legitiment problem, but I can not find wheels with a low offset that will clear my Brembo calipers.
I've called a couple of wheel shops and have come up with nothing, I also want to stay away from using spacers if I can.
Old Aug 11, 2010 | 01:44 PM
  #1712
forweareLegion's Avatar
You can still have a wheel with a low offset that doesn't clear a bbk. Just as you can have a wheel with a higher offset that clears a bbk. It's all in wheel style and more importantly disc type.
Old Aug 11, 2010 | 03:51 PM
  #1713
The Stimulation's Avatar
Is it the offset you want or the lip? Those are two totally different things.
Old Aug 11, 2010 | 04:26 PM
  #1714
Johnnyone's Avatar
^ lower offset usually means bigger lips right?
Old Aug 11, 2010 | 04:30 PM
  #1715
NjMatteSedan's Avatar
i doubt it. You can have a rim with no lip and put spacers and you just lowered the offsets but the lips didn't get bigger. There's some concave wheels with really low offsets as well
Old Aug 11, 2010 | 05:03 PM
  #1716
3crchino's Avatar
Well from the way I had it explained to me, I was told that the lower the offset the more lip you get.
Old Aug 11, 2010 | 05:05 PM
  #1717
Sometimes...depends on the disc type, pad width, and the type of wheel as well. Take for example Ordens...you can have low offsets but lip size won't be that big.
Old Aug 11, 2010 | 05:15 PM
  #1718
3crchino's Avatar
Ok so I want to go for a flush look, by the way I think it was the recruiter for you team donpisto who has a G with brembo calipers and a nice lip. I want to achieve a flush look at the same time have a nice lip, I hate getting the same wheels others already have even though I may end up having to do so. But I guess what can I do to find out what wheels will clear my brembo's
Old Aug 11, 2010 | 05:23 PM
  #1719
4drmadness's Avatar
Old Aug 11, 2010 | 05:29 PM
  #1720
3crchino's Avatar
One word describes this car "Awesome"...... but I guess I was wrong about the brembo's, I do know that I have seen a G with brembos though.
Old Aug 11, 2010 | 05:35 PM
  #1721
Johnnyone's Avatar
Uh yea... i get the part about adding spacers and ur lips not getting bigger.
^ this makes sense and what Levon says below makes sense also.
Take the work vsxx for example, to me it seems like a wheel with -10 offset would have a bigger lip than a wheel that has +10 offset cause the part that bolts up to the hub would have moved backed 20 mm. therefore increase your lips by 20mm
Old Aug 11, 2010 | 05:51 PM
  #1722
Fabrikator's Avatar
yea really depends on the wheel, definately do the homework. some wheel manufacters simply increase the backspacing on the wheel rather than actually mounting the face deeper. sometimes for bbk clearance issues, or sometimes just for manufactoring costs sake.
Old Aug 11, 2010 | 05:52 PM
  #1723
4drmadness's Avatar
yup dont have brembos, but im getting alliance bbk pretty soon
Old Aug 13, 2010 | 01:25 AM
  #1724
4drmadness's Avatar
Old Aug 13, 2010 | 01:41 AM
  #1725
Dranom's Avatar
ill raise you this
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
