OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Feb 9, 2010 | 08:05 PM
  #196
The Stimulation's Avatar
Originally Posted by Ghayes23
^you need camber arms for the front and rear, and toe bolts or toe arms for the rear.
Front camber arms are not necessary. With a drop that still had about 1.5" - 2" from wheel to fender gap (tuckin tire a lil) on a 20x9.5 +3 with a 225/35 I was tucking a little with no upper A arms.
Here's a pic of it...hard to tell from that angle but it's a little tucked. Camber is at -2.4 (again, stock upper A arms which there is no way to adjust).
In this pic I have 20x9.5 -12 (-4.7 camber dialed in with modified Cusco upper A Arms). It looks like it sticks out in this pic, but it's actual flush...if I drop the car all the way down I have maybe 3mm between the lip of the wheel and the fender.
  #197
STCLAIRWEST's Avatar
How much do they run for?
Old Feb 9, 2010 | 08:13 PM
  #198
Battle Version retails for 275. The SPC are 180 from a vendor on this forum (not retail price).
Old Feb 10, 2010 | 04:19 PM
  #199
Do you think I'd be able to run a 225/40 in front?
Old Feb 10, 2010 | 05:13 PM
  #200
Should be fine with that....if there is any rubbing it's going to be one of two places. The sidemarker bracket (shave off a little, i'll take pics and post later) or the fender liner where the firewall is (not the one covering the headlights).
Old Feb 10, 2010 | 05:22 PM
  #201
Because I have a pair of them from my coupe 19s and I would much rather use those so I dont have to buy new fronts. Also the rims come with 245/35 fronts, would I be able to fit those on the rear or there would be issues?
Old Feb 10, 2010 | 06:23 PM
  #202
That might poke out a lil...if you look at the pics 4dr. madness. posted, he's got 235/35's in the rear. 245/35's can fit with a pull with the offset you'll be running.
Old Feb 10, 2010 | 08:07 PM
  #203
G SEDAN's Avatar
bro i dont think you're ready. you should just get some offsets that fit
Old Feb 10, 2010 | 08:12 PM
  #204
OCG35's Avatar
what constitutes "ready"?
Old Feb 10, 2010 | 08:15 PM
  #205
4drmadness's Avatar
Old Feb 10, 2010 | 08:21 PM
  #206
Lol just give me time....Im not even driving my car now cause canadian winter sucks so Ill be done when I bring my car out.
Old Feb 13, 2010 | 11:40 AM
  #207
FlyingLumpia's Avatar
I pushed out my rear alittle more, 10mm more so I am at 19x10 +22 with a 255/35/19 I guess this could be a teaser shot.
Old Feb 13, 2010 | 11:57 AM
  #208
gtrefever's Avatar
looks good.
Old Feb 13, 2010 | 02:08 PM
  #209
04G35NYC's Avatar
+ 2 that looks Perfect.
Old Feb 13, 2010 | 03:32 PM
  #210
G SEDAN's Avatar
research, research, and research.
Keep in mind mine isnt even that aggressive compared to most people in here, but I knew exactly what offset to run, what parts I needed for camber, what tire sizes to go with (undestimated by a bit), what backpad space to clear bbk, what fender work needed, and what camber settings to be at to clear everything. I thought I was ready but I wasn't.
Tires were way too stretched and leaked air. Lip weren't big enough, etc etc etc. It's something that I wouldn't wish on anyone, the headaches that involved getting it to look perfect.
the end result is worth it though....just thought he was still asking some pretty basic questions I thought he might be asking for more than he ancitipate.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
