OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Mar 24, 2010 | 03:31 PM
  #316
heyitzalex's Avatar
Thanks guys!
Marcus - I'm ready when you are
As for the front fitment, it can definitely come out another 5mm, maybe another 10mm to poke out, but then I wouldn't be able to turn. It already hits fender pretty bad on a full turn going up an incline. But I guess if you're not rubbing, your not low enough, lol. Probably should run a 225/35 if I wanna add some more spacer.
Old Mar 24, 2010 | 05:32 PM
  #317
Johnnyone's Avatar
^ I just threw some 15 mm spacers on my fronts making them +9 on a 9' wheel. Perfect amt of poke IMO but im running 225/35's.
Old Apr 7, 2010 | 12:27 AM
  #318
Fabrikator's Avatar
well, this thread more than any other inspired me..
I just ordered my wheels today.. 20x9.5 +14, and 20x10.5 +20
See you guys in 6-8 weeks! Hopefully ill have a few more suprizes to go with it
Old Apr 7, 2010 | 12:34 AM
  #319
4drmadness's Avatar
nicee, those are some good offsets. I think +23-25 is the perfect offset for the rear when it is a 10.5 wheel. In terms of camber and fender work
Old Apr 7, 2010 | 12:40 AM
  #320
4drmadness's Avatar
Heres my setup, still a work in proress. Will be addin spacers in the fronts and rear, and play with camber.
Old Apr 7, 2010 | 01:26 AM
  #321
JDM_Cain's Avatar
Originally Posted by heyitzalex
Hey guys, its been a long time since I posted up anything. Been caught up with other projects, but here are some fitment pics of my recent rim setup. This is it until I get a proper shoot with Marcus.
19x8.5 +12 235/35, 19x10 +25 265/30 BBS LMs
Custom setup done by Status Autoworks formerly known as VIP Status (www.statusautoworks.com)
Nice, I wanna see more pictures of your car.
Old Apr 7, 2010 | 01:28 AM
  #322
gtrefever's Avatar
i had a 9+4 with a 215/35 and it sat perfect throw on a 20mm youll still be able to run a 225/35.
Old Apr 7, 2010 | 03:49 AM
  #323
Fabrikator's Avatar
looks crazy!.. what are your specs?
Old Apr 7, 2010 | 10:33 AM
  #324
Johnnyone's Avatar
If i decide to go lower i will prob throw on the 20mm or 25mm. But at the current height i have the perfect amt of poke cause it matches my rear.
Old Apr 7, 2010 | 10:35 AM
  #325
SN00P's Avatar
CLUB MODERATOR
I'm running a +35 R and right now + 40 F and was going to order the ichiba V2 with a 10mm spacer on the front to drop it to +30 ... would that be close to an aggressive look or would i need spacers in the rear as well ?? im not looking for a crazy aggressive look but a decent looking set-up .. what more should i do ??
Old Apr 7, 2010 | 10:38 AM
  #326
Johnnyone's Avatar
Congrats.. i wish i could run those specs but a 245 35 on a 10.5 and running
-3.5 camber was a lil too much for me.
I think i can get some used 20x11 +15 HRE's locally but man that's just too aggressive for me on coils. If i was on bags and really stretched tire i think i could pull it off.
Old Apr 7, 2010 | 11:23 AM
  #327
Johnnyone's Avatar
Need to know the width of your wheels to help with recommendation.
My recommendation would be to get the height and camber where you want it. Then measure from wheel to where your want the wheel to be. Here is an example of mine.
Old setup. I took a tape measure and meaure where the wheel was at and figured out how far i wanted the wheel to poke out. For my setup i wanted it to come out .5 inches which is 12.7 mm. So i went with 15mm spacer.
And here is the result.
LMK if this doesn't make sense.
Old Apr 7, 2010 | 11:34 AM
  #328
SN00P's Avatar
CLUB MODERATOR
im running 19x8.5 F +40 w/ 245/35/19 and 19x9.5 +35 R w/ 265/30/19 ... i have 350z tein s-techs in the garage but need to get the fenders rolled .. i tried to get in there today but the place is slammed so im going to try and get in there friday ....
Old Apr 7, 2010 | 11:56 AM
  #329
Johnnyone's Avatar
^ TycoRC was running the same width but he was at +20 all around and you can see his specs and what he did for them to fit at:
https://g35driver.com/forums/19-inch...lo-wheels.html
Old Apr 7, 2010 | 12:12 PM
  #330
SN00P's Avatar
CLUB MODERATOR
well i was planning on keeping the rear at +35 and throw on a 10mm spacer for the front to drop it to +30 .. i think that should be a decent setup for now and not to crazy and should look pretty good
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
