OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jun 27, 2011 | 09:17 PM
  #4021
forweareLegion's Avatar
Excessive camber will. But look at the front of a GT car, or even F1.
Best fitment evar.
Here we go;
Old Jun 27, 2011 | 09:22 PM
  #4022
JaE35's Avatar
Moderator
G35 Sedan
that's so sexy lol
Old Jun 27, 2011 | 09:49 PM
  #4023
This car has some of the best fender work I've ever seen, leave it to the Japanese.
JIC J-force, 18 x 8.5 -18 / 9.5 -10.
  #4024
dz n.u.t.z.'s Avatar
Camber is your friend!!! Use it.
Old Jun 27, 2011 | 09:51 PM
  #4025
That's cute!
Old Jun 27, 2011 | 11:23 PM
  #4026
4DGS's Avatar
Ugggh that looks terrible. Has he considered lowering it?
Old Jun 27, 2011 | 11:27 PM
  #4027
Yes, he has.
Old Jun 27, 2011 | 11:32 PM
  #4028
Matzo Ball's Avatar
needs to tuck tire up front IMO. Could use more stretch as well.
Old Jun 27, 2011 | 11:34 PM
  #4029
4DGS's Avatar
Huge spacer up front....
Still needs to go way lower to pull off what appear to be 18s.
Old Jun 28, 2011 | 12:08 AM
  #4030
kyemaul's Avatar
The reason y I asked about aggressive camber begin a problem is because the tires look sick but no flat on the road..
Old Jun 28, 2011 | 12:17 AM
  #4031
CandlestickPark's Avatar
ill Sedan
That black Sedan needs moar low for sure.
  #4032
He bought the wheels for an s14 but bought this car instead. Dont know what his ultimate plans are yet, the JICs have only been on for a couple days so it may yet end up on the ground.
Old Jun 28, 2011 | 12:23 AM
  #4033
ill Sedan
We had the front bumper off installing my tranny cooler so RRYDE modified my bracket even more to get rid of the rubbing up front.
Old Jun 28, 2011 | 12:45 AM
  #4034
ill Sedan
Originally Posted by P10 WRC
Okay peeps, i am going to start buying parts for my stance here pretty soon and just want to make sure i am getting the proper items. I don't want to get too crazy with the stretch as this is my daily driver and the wife will drive it from time to time
My wheel specs right now are
rear fenders rolled
SSR Professor SP1
f 19x9 +31 with 235/35
r 19x10 +37 with 255/35
I am going to get some BC coils to drop it and rear toe bolts. I just have some questions.
1. Will i "need" a camber kit to get the fitment as flush as possible, or will spacers be enough?
2. If i do need a camber kit, what brand do you all recommend? Will i need it for the front and rear, or just the rear?
3. are the 235's in the front not aggressive enough? I could always put them out back and get some 225's or 215's. Keep in mind i do drive it about 50 miles a day on the freeway so nothing too crazy.
4. What size spacers will i need? My rears already poke a bit, but i am sure that will change if i go lower.
thanks,
marty
i want to scrape the street of course. Just kidding, i love how low you are but i don't know if i am ready to be that slammed. i would say 2.5 to 2.75 inch drop
A 2.75 inch drop will look good on a 235/255 setup, I say keep your current tire sizes, particularly since you don't want to run stretched tires.
1. You won't need a camber kit up front unless you want to eek every mm of flushness out of your setup. A rear camber kit is so cheap (less than $200 including the toe bolts) I always recommend people to get one.
2. I recommend the SPC (Eibach is the same thing) or SPL camber rear camber kit. The SPC is cheaper and is great, a lot of us run it.
3. Keep your 235s up front, based on your comments I have a feeling that 225 on a 9 is gonna be a tad more stretch than you want to run.
4. I would aim to be at:
9 +16 (+31 with 15mm spacer) - If you want to be at about the same point as the rear then do a 20mm spacer and pinch your fronts flat (maybe flare a tiny bit).
10 +22 (+37 with 15mm spacer)
You setup will be 5mm more aggressive than when I was dropped 2.5" on my Nismos. Your tires will be a tad more stretched and you'll be .25" lower than I was.
Old Jun 28, 2011 | 01:07 AM
  #4035
M@rCo's Avatar
need more camber in the rear
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
