OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jul 14, 2011 | 07:14 AM
  #4186
Lucky-G's Avatar
Wharchu talkin bout, Robin? ;-)
Ninja edit ftw.
Old Jul 14, 2011 | 10:22 AM
  #4187
cornell's Avatar
Mine is a 19x10 +10 with a 235/35. Camber is at -3 and the tires pull the fenders themselves everytime i turn too wide. Need to go 225/35 but thinking about leaving it 235 putting on my new camber arms for more camber and a bigger spacer
Old Jul 14, 2011 | 12:27 PM
  #4188
cornell's Avatar
But i should probably also mention mine rub because i am 23 and 3/4" fender to ground in the front(because of 4DGS taunting me). Going back up soon
Old Jul 15, 2011 | 01:45 AM
  #4189
bert512's Avatar
help!!!
can i fit 20" wheels f 8.5+25 and rears 10+25 on a g sedan if so what do i need to do?
Old Jul 15, 2011 | 01:58 AM
  #4190
Lucky-G's Avatar
Step 1: remove lug nuts
Step 2: remove OEM wheel
Step 3: install 20 wheel, ensuring the bolt holes are mated properly
Step 4: install aftermarket lugs finger tight
Step 5: torque aftermarket lugs, in a "star"-pattern, to 100-110 lb-ft
Step 6: slam the car
Step 7: enjoy
Step 8: post pics on driver
Old Jul 15, 2011 | 02:09 AM
  #4191
bert512's Avatar
when i test fitted the rim in the rear they stick out a bunch
Old Jul 15, 2011 | 02:15 AM
  #4192
Adil_G35's Avatar
Yea for the sedan a 25 would poke out more than on a coupe. Offsets will vary from coupe and sedan. 25 wont look the same on coupe and sedan
Old Jul 15, 2011 | 02:19 AM
  #4193
bert512's Avatar
so can it be done will these rims with the +25 offsets fit on my ride??
Old Jul 15, 2011 | 02:25 AM
  #4194
Lucky-G's Avatar
check out my pic *****/progress thread. Your wheels will be 2.7mm more aggressive than mine.
Old Jul 15, 2011 | 02:30 AM
  #4195
4DGS's Avatar
Brandon, you're over torquing.
  #4196
Adil_G35's Avatar
not enough information is given. Tire sizes? Are you dropped? Fender rolled? etc...
Old Jul 15, 2011 | 02:36 AM
  #4197
bert512's Avatar
ok...just got the car guy gave me the rims (sevas s55) not dropped no fender work and not sure on what kinda tire size i will need so preety much just seeing what i need to do to make these fit
Old Jul 15, 2011 | 02:49 AM
  #4198
Adil_G35's Avatar
If u arent going to go really low profile then you're definetly gonna need to roll ur fenders bro. better safe than sorry. If ur looking for a drop later on be sure to look into some kits to get the best bang for your tires lol
Old Jul 15, 2011 | 02:54 AM
  #4199
bert512's Avatar
ya def gonna roll the fenders. whats size tires should i run?
Old Jul 15, 2011 | 02:59 AM
  #4200
Adil_G35's Avatar
Well do you want tire stretch? I would run the 245/30 in the front and 265/30 or 275/30 in the rear. Thats without tire stretch. It would look pretty sick. Everyone has their own preferences.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
