OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Sep 19, 2011 | 06:58 PM
  #4516
shawndon's Avatar
Yes it squats when rolling, so when I'm driving it is lower than when its parked.
I already every so slightly graze the lips of the drivers side wheel out back under full compression. It wouldn't rub the tire but rather the lips of the wheels. Nothing a larger fender pull or more camber wouldn't fix, but I like how its sitting right now.
After 6hrs of adjustment, I wouldn't screw with it either. I still rub under full compression as well(I want stiffer coils 12/10FTL). But my main problem is I need a 245/35 out back for more clearance.
Old Sep 19, 2011 | 07:00 PM
  #4517
CandlestickPark's Avatar
ill Sedan
I have 10/8K spring rates on my BCs, running them at full stiff (not my preference but gotta do it so I don't rub). What coilovers do you have?
Old Sep 19, 2011 | 07:04 PM
  #4518
shawndon's Avatar
I'm on BC as well. 6 clicks from full stiff
Old Sep 19, 2011 | 08:23 PM
  #4519
ill Sedan
Scrapin' everyday...LOL.
Note the JDM angle.
Old Sep 19, 2011 | 08:40 PM
  #4520
Matzo Ball's Avatar
lolz. that is not even half the incline of my driveway. Leaking some fluid there?
Old Sep 19, 2011 | 08:43 PM
  #4521
Matzo Ball's Avatar
ugh, I came b/c of Marcus' pics.
Old Sep 19, 2011 | 08:44 PM
  #4522
SN00P's Avatar
CLUB MODERATOR
My driveway looks the same but its more of a incline :/
Marcus do you have a aluminum under panel? ? Are you scrapping that or sways?
Old Sep 19, 2011 | 09:05 PM
  #4523
ill Sedan
Nah that isn't fluid from my car, I didn't even drive it oday (its a common area garage)
Yes, I have the RareJDM alumnium under panel. I didn't attach it to the underside of the front bumper, it would be too low. I attached it above the front bumper so it sits right against the frame. It does scrape sometimes, and does a great job at protecting the undercarriage.
What is scraping in the pic I posted is my Tanabe y pipe. Prior to that I was scraping my OEM cats on that very tiny incline...LOL.
Old Sep 19, 2011 | 10:49 PM
  #4524
NFSP G35's Avatar
? = 2B || !2B
Hey, what's the biggest tire anyone's managed to get on the back of a sedan?
It seems like somebody had some stupid big tire posted on a thread a while back, but I can't seem to find it :/
Old Sep 19, 2011 | 10:54 PM
  #4525
ill Sedan
I think Aaron (G SEDAN) ran a 295 or 305 lemme look...
Old Sep 19, 2011 | 10:56 PM
  #4526
ill Sedan
Yup 295s. He was planning on doing 305s, would have easily fit since his camber was within spec and he had a 10mm+ fender pull.
https://g35driver.com/forums/media-s...g35-sedan.html
Old Sep 19, 2011 | 10:58 PM
  #4527
NFSP G35's Avatar
? = 2B || !2B
^Yep that was the thread I was looking for... I had just forgot it was Aaron.
Man, 305s would have been crazy
Old Sep 20, 2011 | 01:06 PM
  #4528
b-dRizZy's Avatar
lol.. i was running Volks GT7's 18x10 +44 i believe and i had the 295's in the back lol . it was my first setup so at that time i had noo clue about offsets ... now that i sort off do i look back and dam i was rubbing crazy i had no fender rolled or pulled
Old Sep 20, 2011 | 02:58 PM
  #4529
iiiiiekoiiiii's Avatar
Marcus what was your new rear offsets. I lost it with the new wheels. Curious about rubbin.
Cause my 19x10.5 +17 with 255/35 had **** load of clearance. Bc coils maxed out rear on 200mm springs 12k/12k on full stiff. Never rubbed.... did hit more cracks then a crackhead tho
Old Sep 20, 2011 | 03:04 PM
  #4530
ill Sedan
Rears are 10.5 +18 with a 245/35. Fenders are pulled slightly (5mm).
My rears are maxed out on one side and I have a few threads on the other side (my car is just weird that way...LOL)
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
