CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
Quote:
Yeah sux...Originally Posted by JosansG35
It's too bad you won't make it out on Saturday
CandlestickPark
ill Sedan
close
- Join DateJun 2007
Yes 7 series
Quote:
Have fun repairing your quarters when you hit a good dip/imperfection in the road. Originally Posted by JosansG35
For all you who didn't have faith in me: 10 -1 on 225/35/19 with OEM camber
wow...thats gangsta status there!! dang...looks so sick but hope its not a daily problem...u gotta set dampening full stiff now..wanna see full shots
Quote:
Full dampening on 18k rears wouldn't even save those fenders...Originally Posted by G Dilla
CandlestickPark
ill Sedan
close
- Join DateJun 2007
^I was just about to say....
Quote:
its been done before.Originally Posted by JosansG35
CandlestickPark
ill Sedan
close
- Join DateJun 2007
Quote:
Pics of your car?Originally Posted by Lowkeyg35
JosansG35
close
- Join DateNov 2008
- LocationLos Angeles
iTrader Feedback Score(10)
Liked:181 Times in 150 Posts
Quote:
You saw it? lol it's bugging me soo much! I'm not done yet though. Still gotta pull the fenders a little bit and I'll be fine Originally Posted by ronniepetras
Lol I see some yellow marks on the fender burning rubber?
Quote:
All I need is a credit card width of fender clearance with the tires and It will be perfect. That's how my previous setup was and my fenders were never damaged.Originally Posted by Gdup35sedan
You're going to need more than a little pull. You'll need. 15-20mm pull which will more than likely result in the fenders dimpling on the spot welds.Originally Posted by JosansG35
You need credit card clearance to clear the tire, which is the least of your worries right now. What you need to clear is the wheel at full compression which is not going to happen without adding more negative camber. The lip of the wheel hitting the fender head on is going to warp/dent the quarter panel and chip the paint.
I have less than credit card clearance on my wheels, the same way I setup Marcus' car
If you want to do it right and make it look good (not destroying your fenders) spend $180 and get an SPC rear camber/toe kit
JosansG35
close
- Join DateNov 2008
I'm definitely getting a camber kit!Originally Posted by Gdup35sedan
You're going to need more than a little pull. You'll need. 15-20mm pull which will more than likely result in the fenders dimpling on the spot welds.You need credit card clearance to clear the tire, which is the least of your worries right now. What you need to clear is the wheel at full compression which is not going to happen without adding more negative camber. The lip of the wheel hitting the fender head on is going to warp/dent the quarter panel and chip the paint.
