OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old May 18, 2012 | 07:45 PM
  #5641
iiiiiekoiiiii's Avatar
I used to think about pullin the shyt outta my fenders, then I thought about it and feel like it looks like azz from the back. i believe in something called too much poke. And prefer every line on the body to stay untouched. It looks more proper when U can make it work the way it is.
Old May 18, 2012 | 07:46 PM
  #5642
TORETTO's Avatar
daemm peeempin
Old May 18, 2012 | 08:04 PM
  #5643
CandlestickPark's Avatar
ill Sedan
Agreed that's why my rears are only pulled 5mm and I run more camber to clear the lip of the wheel.
Old May 18, 2012 | 08:30 PM
  #5644
MPG35fiend's Avatar
+2
Really? Cant even tell... Looks good!
if thats what a 5mm pull looks like than I'm willing to do it, but only if i absolutely need to..
Old May 19, 2012 | 01:26 PM
  #5645
4DGS's Avatar
**** that, I'll take pulled and manged fenders running aggressive as hell over higher offsets and flat fenders. I honestly hate the straight edge of the fenders.
Old May 22, 2012 | 04:10 PM
  #5646
supreme1911's Avatar
Question for the sedan guys!
Is 18x9 +20 and 18x10 +18 too aggressive for a sedan? I always see sedans only go down to +22
Old May 22, 2012 | 04:31 PM
  #5647
jimmyboi860's Avatar
I think that's great for a sedan
Old May 22, 2012 | 05:12 PM
  #5648
P10 WRC's Avatar
I am currently at 19x9+11 in the front with pinched fenders and shaved side marker bracket. I was fine when i was running +21, just had to take out the fender liner screws. I would stick with +28 in the rear if you can so that the rear won't be poking more then the front, or go with a 10 mm spacer up front to make them +10. you will def need to get the rear fenders rolled flat though. Marcus has a 10.5+18 in the rear but he had to pull the fender an additional 5mm's to make them fit and run more camber out back. Keep in mind, this is with 19 inch diameter wheels, so I don't know how 18's will change that. Check with 4GDS as he had 18's on his ride that were very aggressive.
Old May 22, 2012 | 05:25 PM
  #5649
ronniepetras's Avatar
What do you guys think of my new setup I'll be picking up?
18x8.5 +25
18x9.5 +30
W/like new Nitto NT555
245/40/18
275/40/18
Old May 22, 2012 | 05:37 PM
  #5650
P10 WRC's Avatar
18x8.5 +25
18x9.5 +30
245/40/18
275/40/18
wrong thread man, those won't be agressive. not saying they will be bad though if you like them, they just won't fit into this thread
Old May 22, 2012 | 05:39 PM
  #5651
I know they won't fit in this thread just getting some opinions from people because I'm setup is aggressive right now
Old May 22, 2012 | 05:46 PM
  #5652
MPG35fiend's Avatar
18x8.5 +25
18x9.5 +30
245/40/18
275/40/18
i think they'd look pretty sick!
got 18x8.5+35 all around with 245/40 all around.... look at garage.
lol we are opposite... I'm going aggressive (19x9.5/10.5+22) and your going semi aggressive (18x8.5/9.5)....
any reason why you want to change set? your set up right now looks GOOD!
Old May 22, 2012 | 09:38 PM
  #5653
Lol I wish I could keep my setup trust me I know it looks good but I always have people in my car so that's another problem my car starts rubbing on the tires.
Old May 22, 2012 | 09:57 PM
  #5654
MPG35fiend's Avatar
EEK!... totally understandable..
can't you run smaller tires??
Do you think ill rub with 19x10.5+22 (rear) on 235/35?
Old May 22, 2012 | 11:57 PM
  #5655
I could but their just too much for me I drive my car everyday we have crappy roads out here, but im not sure if you should to be honest I'm no too good with offsets but Im pretty sure you shouldn't because I'm running 245/35 but it barely rubs unless I'm taking hard turn or people in my car
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
