OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Sep 22, 2012 | 08:00 PM
  #6136
JosansG35's Avatar
Work in progress. Off to get an alignment!
Old Sep 22, 2012 | 10:14 PM
  #6137
MPG35fiend's Avatar
Amazing how much sedans have come up over the years... Thanks to the veterans and this forum it's nice to see more and more sedans with aggressive set ups. I'm hoping that there will be more and more "X"s with more aggressive setups since not many of us AWD guys run aggressive or even staggerred set ups at that..... Love this thread! Xs please post more in this thread!!
Old Sep 22, 2012 | 10:35 PM
  #6138
MPG35fiend's Avatar
Originally Posted by PAIXAO
My contribution.
BBS RGR
19x8.5 +18 Front 225/40
19x9.5 +22 Rear 245/40
Need to fine tune ride height and add a touch negative camber in the rear.
love this set up..... rear looks good IMO just a bit more camber will do, front could use a bit of adjustment a tad lower to even the rear... I'm running 19x9.5+22 19x10.5+17 with a 225/40 255/35 (same rolling diameter for AWD) i plan on going with a VERY VERY similar stance as yours since my stretch is mild and meaty stretch....
still havent adjusted the STANCE since ive been focussing on my engine bay.....
sick bro.... i wish i could run a stance like that, but i cant since the Xs cross member bar sits significantly than RWD.
Old Sep 22, 2012 | 11:07 PM
  #6139
PAIXAO's Avatar
Thanks for the kind words. I just bought and mounted them today. I plan on lowering the front and adding that camber in the rear.
Ultimately I plan on 255/35 rear tires and 245/35 front. I may add a 5mm spacer up front. I was just so excited to pick these up, I had to put them on today and share.
Old Sep 22, 2012 | 11:30 PM
  #6140
MPG35fiend's Avatar
yea i plan on doing a 5mm up front as well after adjustments... i plan on lowering the rear half an inch to an inch and setting at -2.0 to -2.5 and dropping the front a quarter of an inch and setting the front -1.5 to 2.5 depending on how it looks. ultimately would like to do -2.0 all 4 corners (willing to do play it safe as long as it looks good) ... since I'm AWD i figured i cant go super aggressive as of yet, (until someone figures out a meaner stretch with the same rolling diameter) so ill take it how i can get it!
Old Sep 23, 2012 | 12:24 AM
  #6141
PAIXAO's Avatar
I know my camber is the same on both side as it sits now, so I'm just going to adjust it myself until it looks the way I want.
When someone asks me what camber I'm running in the rear I'll just say "I don't know, but it fits"
Old Sep 23, 2012 | 12:46 AM
  #6142
MPG35fiend's Avatar
Good idea! I'm just going to adjust camber myself as well... I never thought about that...
Old Sep 23, 2012 | 03:31 AM
  #6143
JosansG35's Avatar
hellastupida$$camber
Old Sep 23, 2012 | 07:09 AM
  #6144
MPG35fiend's Avatar
Looks crazy sick though! I want that stance man.... I may buy a RWD Aand swap my parts to have that stance!!! Lol. Nasty.
Old Sep 23, 2012 | 11:42 AM
  #6145
cloudless_skiez's Avatar
you can still be stance with an X just don't be scared to slam it. i'm at 23.5in measuring the tire to fender in the front.. flyinglumpia "hopefully i spelled his name right" he was or still is a stance X. anything is possible.
Old Sep 23, 2012 | 12:09 PM
  #6146
Gdup35sedan's Avatar
ENVautoDetailing.com
23.5" is lower than both Marcus and I.... Pics or it didn't happen on an X. Youd be scraping the front diff subframe on flat ground
Old Sep 23, 2012 | 12:52 PM
  #6147
MPG35fiend's Avatar
Man... I'd like to see how that looks! Pics please!!!!
Old Sep 23, 2012 | 01:39 PM
  #6148
Drew113's Avatar
Ban Hammer Expert
Damn those BBS look clean man, props PAIXAO!
Old Sep 23, 2012 | 09:48 PM
  #6149
4DGS's Avatar
23.5 is a like a 1/4" higher than I was last year. Your front diff would be in the ground if you are at 23.5
Old Sep 23, 2012 | 10:40 PM
  #6150
SDGenius's Avatar
^so ur diff was on the ground?
*wait, you meant the front X diff... nvm
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
