6k/3k installed
Old Jan 11, 2011 | 03:39 PM
  #151
g35newbie3's Avatar
Originally Posted by thescreensavers
what exactly is giving that scattered light look the fog? Then its because you took the shield off most likely.
If its the low beams, then I have no idea did you buy the right bulbs?
No I bought the right ones. H4 6000ks.
Originally Posted by G GS
Did you get the D2R bulbs? The bulb you were holding in your picture doesn't look like a D2R.
And that bulb is from my old HIDs.
But I have figured out the problem. Looking at them in disgust again last night, of how crappy they look, I figured it out. If my old bulb was that small and was able to fit into the housing and clip in and was projecting correctly then something is wrong now.
Well my bulb is not all the way in (the exactly reason why it is projecting the whole inner headlight housing, and making eyelashes) due to the plastic backing on my new bulb, because they do not fit all they in and clip down. I can almost guarantee, I cut the plastic and fit them in correctly it will solve my problem.
Stay tuned. Thanks again for the help guys. It helped me brainstorm a little bit. This weekend I will fix them up and post pics of the install.
Old Jan 11, 2011 | 06:24 PM
  #152
TurTLe*'s Avatar
Originally Posted by g35newbie3
Ok now that its dark out I went to look at the lights.
On the road
It literally looks like I have no headlight on. My light is basically all over the place except on the road.
My lights look like this
I have super eyelashes and I have no clue how to fix it. Because the low beam headlight housing doesn't allow room for the bulb and the shield.
HELP!
WOW... you sir are worst the most of the ricers on the road. take them off please.
looks exactly like how a halogen housing should reflect a HID bulb. See that 1st picture NONE of the lighting is making it to the floor, its all shining at the owls, squirrels and aliens. Aiming them lower will not help much because its still all over the place.
Old Jan 11, 2011 | 09:17 PM
  #153
thescreensavers's Avatar
Mr.202?
Its H4 for the fogs, you should not need to cut anything. There are notches so you put in the bulb the proper way, did you do that?
Old Jan 12, 2011 | 12:31 AM
  #154
g35newbie3's Avatar
haha yes, not driving the car currently due to the fact I can't see anything. Aiming them lower won't help, looked back at my order from DDM and I ordered wrong kit. Great over look and a definite newbie move. AHHHHH great.....and now DDM is no longer stocked with D2R kit. haha thanks for finding humor in mishap.
You are correct, I bought H4 6k's not realizing I didn't order the D2R kit. I really thought I had the correct kit (when I was looking at the H4 6ks). So right now back to square one. Correct, man me and you went back in forth on this. Haha all the pictures and everything. Thanks again Screens for your help
Haha sorry for the confusion guys, just thought I was getting jacked around.
Found a spot here in Elk Grove actually that has the right kit, same price as DDM, just not slim ballast. Which is fine, just need to pick them up tomorrow and put them in after work.
Old Jan 12, 2011 | 02:34 AM
  #155
sTeadFasT96's Avatar
I really don't think that was his desired effect...so would that still make him ricer? Also considering he's seeking for help.
Personally, I would go back to stock until you find a solution. With my experiences with "bi-xenon" bulbs, they tend to be horrible. I would say either stay stock if you want your high beams or stick with a single beam bulb.
Old Jan 20, 2011 | 04:30 PM
  #156
TurTLe*'s Avatar
DDM is going a different route, so no more slim kits for anyone. Kinda said that i finally made up my mind about getting HID fogs now and they are done. It tells me it wasn't suppose to be. So i'm sure someone will come in and take over hopefully.
Old Jan 20, 2011 | 05:14 PM
  #157
g35newbie3's Avatar
Yeah I saw that. Haven't been able to post pics up yet of my new lights. Bought a kit for 55 and they aren't slim ballast. Install quick and easy. I'll post them up tonight if I get a chance
Old Jan 20, 2011 | 06:18 PM
  #158
b-dRizZy's Avatar
i have same setup 8k up 3k down
Old Jan 20, 2011 | 10:46 PM
  #159
liljohnny's Avatar
Ya, stay away from DDM, they're getting out of the lighting business....
Old Jan 20, 2011 | 11:01 PM
  #160
liljohnny's Avatar
What kit did you buy? A kit for the low beams or the high/fogs? I'm confused....
Old Jan 21, 2011 | 07:12 AM
  #161
TurTLe*'s Avatar
why would you say stay away.... the owner of it is on most bimmer forums. He posted he wanted to veture into other stuff. i forgot what but he was still making bimmer related parts. His kits aren't bad at all from the 2 i've install for friends.
our cars aren't designed to house HID bi-xenon lights. the HID bulbs dont follow any regulation like the halogen bulbs we have OEM. So there is no telling what that is going to do. Its not DDM's fault, nor it is Nissans. Its just not compatible, beside all HID kits have the " not for road use" labels on them. So if you do glare up things your not suppose to be on the road be begin with.
Nothing wrong with the company.
Old Jan 21, 2011 | 02:19 PM
  #162
g35newbie3's Avatar
I bought the H4 3k kit from DDM for my fogs off of DDM and I ordered the wrong low beam kit from DDM so I had to buy a new low beam kit.
I bought them from a place here in the Sacramento/Elk Grove area for 55.
Same kits as these some of these:
http://www.hid-conversion-kits.com/b...nversion-6000k
Old Jan 22, 2011 | 10:03 AM
  #163
G35 Drummer's Avatar
It sux that DDM is not sellin gthat kit anymore.
Anyone knows where i could get a good H4 Kit?
PM me...thanks
Old Jan 22, 2011 | 02:26 PM
  #164
G GS's Avatar
So I went to install some new HID fogs last night I purchased from DDM. I got the 35W slim ballast (I'm assuming I was one of the last ones to get my hands on one of these from what I've been hearing about DDM going another route. This made me wonder though how DDM would back up their lifetime warranty on their HID kits if they won't be carrying them anymore. I suppose they can just give us a refund without replacing the parts).
But back to my main concern. I have an 05 coupe and while installing the fogs I realized that I couldn't re-cap the fog housing due to the ballast's wires. So for the coupe guys, how did you guys end up capping the fog housing? Drilling, shoving everything in there, or another alternative? I appreciate the help.
Old Jan 25, 2011 | 02:21 PM
  #165
Mr.202?
^ I looked into it.
DDM is moving away from HID's being their main focus, but they will still be selling them, and they WILL back up their lifetime warranty.
Currently the slim Balast that I purchased and what many people buy is out of stock, and will re-appear once they get them in.
